PWM to DC
Madman
3,001
Pennsylvania, USA
I may have brought this subject up before. I am still trying to work out how to do what I want to do. I have an LGB DUO switching locomotive. Using it on track power with an LGB transformer, it works as it is supposed to. However, using it with my G Scale Graphics Railboss system, it does not.
The Railboss system puts out a form of PWM. All of my other locos, be they LGB, Bachmann, USA Trains, all work well with the Railboss system.
There must be some sort of electronic device that will convert PWM to straight DC, but I have yet to find one. There may be plans available to build one, but I don't want to go down that rabbit hole.
The device pictured only works with the Revolution system. I don't want to get into a whole 'other system.
Rhinochugger
Retired Oik
4,254
North West Norfolk
The answer may be in the loco - PWM shouldn't have a negative effect on a motor's performance, although some motors reportedly whine on PWM.
PWM is quite widely used in the smaller scales to give smooth, slow starting and prevent the startled rabbit method of leaving a station ;)
So, is there something in the LGB Dou circuitry that doesn't like PWM?
Cobalt6700
2 Jul 2020
125
33
UK - Oxfordshire
Madman Madman can you post some close up pics of the DC DUO control board in this thread?
I would suspect the easiest way to make the couplers work is to loose the DC DUO board and run something like the DCC DUO board (or relays), which can be driven by the sound/function outputs on the Railboss controller.
Madman
3,001
Pennsylvania, USA
That sounds promising. Del Tapparo declined to delve into anything to do with my DUO loco. I suspect he's happy with the status quo and don't want to risk any fallout.
That said, there are two electronic gurus on Model Train Forum that I may post the question to.
Dan
28 Jan 2010
663
52
Eastern MA, USA
In order to operate the factory LGB duo on DC one needs to slowly turn the speed, stop while uncoupler works, then speed up. Unfortunately pulsed power really does not have linear speed as pulses are sent out at full voltage, it is the spacing between these pulses that determines the motor/engine speed. There are some DCC decoders that do not like these pulses and to run these on pulsed power systems one needs a filter to 'smooth' the pulses to almost pure DC. The MRC 6200 is one unit that these filters work great on as some DCC engines run but very slow until the filter is added to the MRC6200.
