Massoth reed switch replacement
richand26mhz
25 Apr 2010
298
15
Penkridge
Hello. Went to use my engine with sound and was getting a constant whistle. The reed switch under the engine glass had gone. Are you able to get replacement tubes to solder on?
3,564
Yes, but need to know how long the original is? - They come in different lengths..
richand26mhz
25 Apr 2010
298
15
Penkridge
The tube is 10mm with the wires an overall length of 20mm with the wires.
LGB333
Active Member
TRADER
15 Feb 2015
689
43
McLean Virginia
www.olddominionrailways.com
3,564
The glass reed switches are available at Champex-linden.de in Germany: CHAMPEX-LINDEN
Is it one of the later listing?
The pack of ten bare reeds, they say is not suitable for the LGB 17100?
LGB333
Active Member
TRADER
15 Feb 2015
689
43
McLean Virginia
Okay, using them
Okay, if you use that LGB 17100 device for controlling track switches, etc. But for the use of regular track magnets, they should work fine as replacement reeds on a reed switch installed in a locomotive.
