Making 3d signs in multi colors!
Mark Janzen
G Scale Layout
18 Jan 2023
10
Roseville, CA
I’m a newbie and using Tinkercad to create multi color building, etc. signs by changing filament colors at different layers for lettering and boarders. Can’t figure out how to incorporate graphics like a barber pole or ?. Any ideas on how?
sircastor
3 Apr 2024
5
1
43
Portland, OR
With FDM printing, integrating colors into complex shapes is a challenge. You can either design your parts to be printed in individual colors and then assembled (this is tricky when it comes to interlocking parts like a barber's pole) Or you can switch colors while printing the layer (which is very time consuming, and if you only have one extruder, it tends to waste a lot of filament)
I'm not familiar with TinkerCAD and its toolset. I personally do this in my slicer. I use OrcaSlicer (which is a derivative of BambuSlicer, which is a derivative of PrusaSlicer) which has a paint mode where you can define which colors to use where. You can paint by a surface, by a layer height, sometimes constrained by the topology of the model. Is the picture you included stuff that you've printed, or something that you're trying to print?
Mark Janzen
G Scale Layout
18 Jan 2023
10
Roseville, CA
Thanks for the insight into "paint" slicers. I design in TinkerCad and use the PRUSA slicer to edit layer coloring and output BGCODE to my Prusa Mini+. The objects in the pic are several of the 80 signs, etc. I've printed for my G Scale backyard model railroad.
justme igor
17 Apr 2020
682
64
Netherlands Westwoud
Netherlands
From what i know you must have a printer with multiple heads.
Or tell your slicer to stop at a certain layer to change the filament.
I just print the whole thing and do some painting.
Indeed print in interlocking parts with one head.
Mark Janzen
G Scale Layout
18 Jan 2023
10
Roseville, CA
I wish I had printer with multiple heads!! It’s time consuming to switch filaments colors! But my painting is terrible. I’ve be told to try ink rollers and will give it a try.
justme igor
17 Apr 2020
682
64
Netherlands
Ink rollers? I did not know that they where also in small size.
I used sometimes dish cleaning sponges.
you can cut one into .300x.300(1x1cm) and "stamp" with it.
GAP
14 Jun 2011
4,066
947
Australia
Spread paint very thinly on a rubber mat, then lay the sign onto the paint similar to using rubber stamps on a pad.
Or try using a rubber stamp ink pad then coat the sign with a clear coat.
Exador
7 Nov 2019
14
2
68
Southern California
The small foam brushes at home depot will paint the lettering tops perfectly in 1-2 passes.
