Empty Spools
1,724
My No2 Child has got a 3D printer,, which seems to work very well for her. The only gripe I have is that the spools that carry the plastic thread are non-returnable.
Does anyone have any (polite) suggestions as to what to do with them, as it seems an awful waste
playmofire
23 Oct 2010
8,299
857
80
North Yorks
A photo of them may help, Paul.
David1226
8,036
74
Abingdon, Oxfordshire
United-States
That sounds like a reel problem
mike
Master at annoying..
4,507
Rossendale
Used mine to store Christmas light ,
GAP
14 Jun 2011
4,084
955
Australia
I put mine in my council provided kerbside recycle bin.
playmofire
23 Oct 2010
8,299
857
80
North Yorks
If an appropriate size, they could provide a basis for loads.
3,564
2" video tape spools, would be cut in half, and used for hanging patch leads, test leads etc.
But I doubt most have that many test leads?
1,724
There you go. The idea of *********** light holders is a good one, but I was thinking more of recycling them back to their original use. I would have thought a return/ deposit system could have been set up
5,025
76
I had some rather nasty black ones that I covered with coffee stirrers to make an empty cable drum load load with. But that would probably only account for a couple at best.
justme igor
17 Apr 2020
690
67
Netherlands Westwoud
Netherlands
some can be reused as raw material to make filament.
Cut them up grind them down what ever to make them smaller is needed.
Melt (a small melting oven with temp control can do the trick) and extract thru a nozzle your new wire.
Basics are pretty simple, guide them into a "canal" of water, reel them up and print again.
