![United-Kingdom Country flag](https://gscalecentral.net/misc/flags/shiny/32/United-Kingdom.png)
I am posting here but it is also relevant to freight wagons.
I came into this garden railway project after most of the rolling stock had already been purchased. We have a high proportion of second hand Locos, passenger coaches and freight wagons. Some train combinations can be run without a problem but we have a regular derailment problem with some coaches and wagons.
The freight wagons were problematic but in most cases they had badly worn plastic wheels, they have now been replaced by metal wheels and run well. However we still have occasional derailments and uncoupling's.
For some reason some passenger coaches derail and often flip, usually in the same part of the track and usually a curve. As far as I can see the track is flat, level and unobstructed and i can see no reason why this should happen.
The minimum radius curve is a 3.
As items have been purchased from multiple sources there is no single frame of reference. I have found that, for both Locos and rolling stock, some have a coupling at both ends and some only one end. Is there any logic to this?
Is it possible that during a turn on a radius 3 curve a double coupling could lock at both ends and flip a coach?
Do metal wheels wear to a point that could cause an issue? I don't see significant wear on the problem coaches.
On my own N scale layout I use a tiny amount of pritt stick on the couplings to stop them uncoupling, not something which would work on G scale. Is there some way of preventing unwanted uncoupling with these coaches and wagons.
Robin
Robin
