Bi led, Common Anode or Cathode
collectors
16 Apr 2022
277
11
67
Norfolk UK
www.chrismorris.co.uk
Hi, wanted to fit a Bi-led to front & rear "Red/White" for direction lights on terminals P1 & P2 & wasn't sure if i should be buying Common Anode or Cathode. Or have i got this part wrong ??
ge_rik
1,251
Cheshire
www.riksrailway.blogspot.com
Are the P1 and P2 on a Deltang or Micron receiver or on something else?
Rik
3,564
Rik
What I was thinking..
IF I could have got into the website :rolleyes: I would have posted a link to the LED wiring information there..
collectors
16 Apr 2022
277
11
67
Norfolk UK
Rik
Sorry, yes a Deltang or the new Micron receiver. I have both.
3,564
Either set of instructions will give you the information..
Pads 1&2 give 3.5V when 'on' and so you connect (with resistor) from the pad to battery negative.
You may find that you can get two-lead, bi-colour LEDs more easily?
You can connect these between Pads 1&2, don't forget a resistor, but are limited to two LEDs due to current limits of these outputs.
The 'A' & 'B' outputs, can give you a lot more current capacity, but switch to 0V when 'on'.
So you connect to the battery positive. Again, don't forget the resistor.
<Edit> You can not use these outputs for two-wire bi-colour LEDs. - When they are 'off' they are 'open-circuit', so no connection.
collectors
16 Apr 2022
277
11
67
Norfolk UK
Hi Phil. with using the 2 wire led, am i right in that P1 & P2 change polarity when the train is changing direction to get the led to go from red to white. ??
JimmyB
23 Feb 2018
7,083
943
70
Weston-super-Mare
www.tumble-down-falls.co.uk
I use two wire twin colour LED for lights, however I attach them (with the appropriate resistor) to the motor connectors, so applying power, even before the loco moves the lights come on :)
3,564
That is correct..
3.5V supply for your resistor calculations.
See this:
  • Leaflet - LEDs.pdf
collectors
16 Apr 2022
277
11
67
Norfolk UK
That is correct..
See this:
Hi, with the 2 wire bi-led, is this correct ??? Thanks (This image has changed to correct the connections)​
3,564
No.
(Now yes, as above drawing has been corrected.)
You wire the LEDs (and resistor) between Pins 1&2..
Pins 1&2, are 3.5V when 'on' and 0V when 'off', so when you change direction the polarity of the voltage between Pins 1&2 changes.
collectors
16 Apr 2022
277
11
67
Norfolk UK
No.
I changed the previous image. Any better ??
JimmyB
23 Feb 2018
7,083
943
70
Weston-super-Mare
It still looks incorrect to me, just connect to P 1 and 2 - short leg from one and long leg from the other on P1 and opposite for P2
3,564
Very scrappy drawing:
If they light incorrectly, just swap the wires to P1 and P2.
collectors
16 Apr 2022
277
11
67
Norfolk UK
Thanks Phil. Whats the old saying, a picture paints a thousand words. I was thinking how to get a negative into the circuit & forgetting P1 & P2 care swapping this side over every time you change direction with the train. Can also see Jimmy B's logic on coming off the motor as many might not be RC. Thanks for your patients guys. :)
PS: have changed the image again.
3,564
You got it. :)
What did you use to draw your diagram?
I am still looking for something to do mine..
ge_rik
1,251
Cheshire
I was going to say, it looks ok to me, so why is Phil saying "No" :wasntme: ...... Then I read further..... :)
Rik
3,564
Now I'm not sure whether to take out all the entraneous information?
:D
ge_rik
1,251
Cheshire
You got it. :)
Hi Phil
Not sure what Chris uses but, as you know, I used to use PowerPoint. However, I recently had to buy a new laptop and baulked at the idea of paying an annual sub for MS Office. So, following GregH's advice, I downloaded and installed Libre Office which does everything MS Office does but also includes a very good Draw program.
Rik
collectors
16 Apr 2022
277
11
67
Norfolk UK
,You got it. :)
Its actually a WYSIWYG web page/site builder that i used to build many websites but moved on to WIX now as its free. The website builder is also free. Go to this page & download If you need any help let us know.
