Bachmann 38 ton 2 truck shay
Cranford
Theatre, Model railroads, GCR
29 Jan 2010
174
4
Leicester
I have a 38 ton 2 truck shay that is dcc ready, I would appreciate some assistance regarding what decoder is available to plug in and where is it accessed. I do not have a manual for it but have looked on line and only found break downs ,not advising how to take it apart.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
I think you could find a Zimo, and there are some others in the US, which does not help you.
You might entertain getting the adapter board that plugs in and has wire pigtails and then use a decoder with screw terminals,
Brixham
27 Aug 2010
1,501
120
There's this....
But it's for a battery dcc conversion......some bits may be useful
Malcolm
Cranford
29 Jan 2010
174
4
Leicester
There's this....
Malcolm
Its a starting point , thanks Malc.
Cranford
29 Jan 2010
174
4
Leicester
Finally accessed the main board, only 2screws, but a previous perso had completely ruined one of the screw heads which meant drilling the head off.
Once in , it is a bit of a maze of mainly black wires, nothing like the only wiring diagram I found on line for it, plus it’s supposed to be dcc ready, there is no obvious connections for a decoder. Any further advice would be helpful.
Cranford
29 Jan 2010
174
4
Leicester
Picture not good, tried again
Dan
28 Jan 2010
663
52
Eastern MA, USA
I thought the board on the bottom was for the lights and smoke. I have found the Bachmann boards inside the coal bunker.
Cranford
29 Jan 2010
174
4
Leicester
Thanks for your comments, now having difficulty in removing tender body, no obvious fixing screws. ???
3,553
I think it is two under the front corners, and one from the top, under the 'filler', centre-rear.
But this is from the dim and distant recesses of my mind. :wondering:
AlanL
1 Mar 2016
148
19
Northampton
Have you tried lifting the water hatch, fixing screw hidden below?
Al
Cranford
29 Jan 2010
174
4
Leicester
Al
Found one screw under water hatch, someone else had tried to remove it, finally got it out, it’s only one screw the front is on lugs. Inside there are 4 wires on the board not connected to anything , 2yellow, red and black, the other 8 black wires are 2 to the rear motor and the other 6 to, I presume front motor and lights.
As can be seen absolutely nothing like the wiring in the video
Cranford
29 Jan 2010
174
4
Leicester
Did you buy this new? The main board is missing.
It is not mine, a colleague asked me to fit a loco decoder, as it said on the box , dcc ready, I assumed it to be a relatively easy thing to do. He said it was new or he was told it was new. Damaged screw heads tell me differently.
I think it is an early Chinese model as it has filament lamps.
3,553
What is on the end of all the black wires in the last photo?
Did you try to run it before you started?
Cranford
29 Jan 2010
174
4
Leicester
I know it’s not safe to presume anything 2 black wires go to rear motor the other 6 go to the board in pic 1. No I didn’t run it as the owner had. If the main board has been removed, as Gregg suggests it is missing, why leave the wires plugged in as they are. I have a feeling someone else has been into it and given up.
Next step is to put it back together and run it on the rolling road.
Rhinochugger
Retired Oik
4,254
North West Norfolk
Some of us have to clean-up after them! :p:rolleyes::D
Yeah, Big Bertha was one such, but a bit more devious. I bought it allegedly new from Steve the Shop as he had been given an amount of surplus stock by Bachmann (at a price) from a shop that had ceased trading.
The conclusion that we came to was that the loco had been opened up, meddled with, put back togetherish and returned to the shop for a refund, and neither the shop owner nor Bachmann realised that it had been 'got at'.
(Steve and I easily came to an agreement.)
