hornbeam - 30/11/2009 7:58 PM
Hi All,
Ive got a factoey LGB chip I want to use. Prob is i've got the conectors and wires but cant remember where the motor wire loom conects. is it to the conector marked M1 or M2?
also which wires of the block go to the track? the two outer ones?
appreciate your help.
Cheeky Monkey - 30/11/2009 8:27 PM
Thats a diag for an add on chip, I've never seen a diag for a factory fitted
Zman - 2/12/2009 1:18 PM
I have the original document as a PDF, for those who want a copy could you email me with your details![]()
</p><p>I may be good, but not THAT good at guessing email detailshornbeam - 4/12/2009 9:28 AM</p><p>Yes please!! And many thanks for all the help guys.Zman - 2/12/2009 1:18 PM I have the original document as a PDF, for those who want a copy <u>could you email me with your details</u>![]()
</p><p> </p><p>And I'm not that good at working out the direct links, but its also possible to get a copy by googling</p><p>CV description for LGB onboard decoders October 5, 2004</p><p>Then click on the link</p> <h3 class="r"><a href="http://www.google.co.uk/url?sa=t&source=web&ct=res&cd=1&ved=0CAcQFjAA&url=http%3A%2F%2Fwww.grossbahnen.de%2Finformationen%2Flgb_lehmann%2FLGB_Onboard_Dekoder_CVs.pdf&ei=bZUaS7KSK8yv4Qaf2onwAg&usg=AFQjCNFRSDbIuN2WcYz9OGgtLdSC0OaUaw&sig2=42YaxYLax0ZRQCtIJQmKDQ"><em>CV</em>-Beschreibung für <em>LGB</em>-<em>Decoder onboard 5</em>. Oktober <em>2004 CV</em> <strong>...</strong></a></h3> <p>It will download a pdf copy of the original LGB instructions in D/E languages.</p><p> </p><p>Apologies for not giving a more direct link but I cannot locate it on the grossbahnen.de website from the menu nor can I copy the Google link - it just downloads the file.</p><p> </p><p>That might just help to avoid guessing email details <img border="0" alt="Smile" src="../jscripts/tiny_mce/plugins/emotions/images/smiley-smile.gif" /></p><p> </p>Zman - 5/12/2009 4:35 PM <p></p><p>I may be good, but not THAT good at guessing email detailshornbeam - 4/12/2009 9:28 AM</p><p>Yes please!! And many thanks for all the help guys.Zman - 2/12/2009 1:18 PM I have the original document as a PDF, for those who want a copy <u>could you email me with your details</u>![]()
</p><p>
</p><p>Ah, that's where it went - my original link no longer worked and didn't have time to relocate it, hence the offer to email the PDF which I have storeddon9GLC - 5/12/2009 5:31 PM</p><p>And I'm not that good at working out the direct links, but its also possible to get a copy by googling</p><p>CV description for LGB onboard decoders October 5, 2004</p><p>Then click on the link</p><h3 class="r"><a href="http://www.google.co.uk/url?sa=t&source=web&ct=res&cd=1&ved=0CAcQFjAA&url=http%3A%2F%2Fwww.grossbahnen.de%2Finformationen%2Flgb_lehmann%2FLGB_Onboard_Dekoder_CVs.pdf&ei=bZUaS7KSK8yv4Qaf2onwAg&usg=AFQjCNFRSDbIuN2WcYz9OGgtLdSC0OaUaw&sig2=42YaxYLax0ZRQCtIJQmKDQ"><em>CV</em>-Beschreibung für <em>LGB</em>-<em>Decoder onboard 5</em>. Oktober <em>2004 CV</em> <strong>...</strong></a></h3><p>It will download a pdf copy of the original LGB instructions in D/E languages.</p><p>Apologies for not giving a more direct link but I cannot locate it on the grossbahnen.de website from the menu nor can I copy the Google link - it just downloads the file.</p><p>That might just help to avoid guessing email details <img border="0" alt="Smile" src="../jscripts/tiny_mce/plugins/emotions/images/smiley-smile.gif" /></p><p>Zman - 5/12/2009 4:35 PM <p></p><p>I may be good, but not THAT good at guessing email detailshornbeam - 4/12/2009 9:28 AM</p><p>Yes please!! And many thanks for all the help guys.Zman - 2/12/2009 1:18 PM I have the original document as a PDF, for those who want a copy <u>could you email me with your details</u>![]()
</p><p>
hornbeam - 6/12/2009 11:38 AM
My problem is now i connect it all up, it doesnt go anywhere and the motor block makes a high pitch noise. Any ideas guys?
</p><p> </p><p>Its worth carrying out a reset to default values. Write 55 to CV 55, then try again. Its also worth doing this a couple of times just to make sure.</p><p>I would also try to read a few CVs , for example CV7 and CV8 to confirm that you have communication with the decoder. </p><p>If you are still having problems here are some questions that may help point you in the right direction -</p><p>(1) What DCC system are you using? </p><p>(2) And how many speed steps is it set to? </p><p>(3) Have you tried using analog?hornbeam - 6/12/2009 11:38 AM My problem is now i connect it all up, it doesnt go anywhere and the motor block makes a high pitch noise. Any ideas guys? thanks again
