Well that doesn't sound at all good. If it can still be programmed I would try a factory reset of the CVs (apparently this will not alter the sound). From the manual:
4.3 Resetting to factory pre-set values
You may rest the decoder settings to the factory pre-set values at any time. Write value 08 in CV 08. A reset of the sound files is only possible with the aid of the LokProgrammer 53451.
This should reset everything including the address to number 3.
