Would someone post the Following Dimensions of the LGB FORNEY ,
N
norman
1 Jan 2013
67
5
Hello,
1) Driver Wheel Diameter ( Excluding the Flange, just the Actual Wheel Diameter )
2) Smokebox Front Diameter.
Thank you,
Norman
FatherMcD
FatherMcD
13 Mar 2014
34
9
Idaho
Just happened to have mine sitting on the workbench. Drivers: 37.5 mm, Smokebox: ~50 mm. There is a slight ridge around the front edge of the smokebox. 50 mm is the diameter over that ridge. The smokebox itself is closer to 49.5 mm.
N
norman
1 Jan 2013
67
5
Thank you !
Norman
N
norman
1 Jan 2013
67
5
Hello,
Could someone post the LIONEL 0-6-0T
Cab Width
Driver WHEEL Diameter ( Excluding Flanges )
Thank you,
Norman
