Workshop/shed build
Rhinochugger
Rhinochugger
Retired Oik (IBT)
940
North West Norfolk
Apparently, this UV activated adhesive was developed from stuff used by dentists
Rik
Probably best not to eat it then :p:p
Reactions: Jotom
Rhinochugger
Rhinochugger
Retired Oik (IBT)
940
North West Norfolk
Thanks. Very helpful and reassuring.
Yes, 2.5mm twin and earth for the sockets and 1.5mm for the lighting. Using a CCU with a double pole RCD and a single pole MCB (rated 16A) for all circuits at the mo. When funds permit, I'll change this for one with two mcbs. I see they're quite reasonably priced on Amazon.
Rik
One thing I did forget to mention - having just been playing in the shed and, in the light of this thread ('scuse the pun) glanced up at the CCU - when running cables to and from the CCU in a shed or garage where there is a risk of condensation, run the cable up to it and, if bringing cables in from above, leave enough to put a 'U' in the cable so that you are always bringing the cable up to the point of entry in to the CCU.
Yeah, I know there'll be a sealing gland there, but better safe than sorry :nod::nod::nod:
JimmyB
JimmyB
23 Feb 2018
2,387
445
65
Weston-super-Mare
Any cables going in to, or out off a hole, should have a "U" drip loop, favourite being aerial in to the house, lot of people forget these.
Rhinochugger
Rhinochugger
Retired Oik (IBT)
940
North West Norfolk
You also need to remind BT :lipssealed::lipssealed::lipssealed:
ebay mike
ebay mike
6 Dec 2011
2,695
309
Norfolk - edge of nowhere.
Rik
Does it work on LGB plastic Rik?
ge_rik
ge_rik
281
Cheshire
www.riksrailway.blogspot.com
No idea. But if it works on the Flexi plastics used on specs then I suspect it'll work on lgb plastic
Rik
P
461
56
PS hmmm, thinking about it, on sub zero nights, presumably the fridge would cease to operate as the outside would be cooler than the inside of the fridge...... Might need another argument.
But if your shed is snug, it should be warmer inside
ge_rik
ge_rik
281
Cheshire
Have now more or less finished the workshop. There's still a bit more titivating to do inside, but it's now usable. In fact, I've started working again on railway related projects (painting some figures bought at Llanfair). A couple of pics of the interior.
And a timelapse video showing the construction.
Rik
  • Love
Reactions: Paul M
909
Tamworth, Staffs.
Very nice! .. When can you start here? :rofl:
i know your next project.. Decorate the Conservatory!! :eek::nod::nod:
ge_rik
ge_rik
281
Cheshire
Blogged what I dun here for those who might be interested
Rik
idlemarvel
idlemarvel
Neither idle nor a marvel
13 Jul 2015
1,920
186
Ascot
Very nice inside but where is the train set? :)
Too late now for you, but did you consider using shiplap rather than overlap for the cladding?
More expensive but less prone to warping as it dries out.
ge_rik
ge_rik
281
Cheshire
Cost was a significant factor, so dismissed shiplap when doing the calculations. My mate built his workshop from feather edge twelve years ago and it's looking pretty good still. Used only one screw per batten for each plank to allow for shrinkage.
Rik
P
phils2um
Phil S
11 Sep 2015
448
235
Ann Arbor, Michigan
Color me green with envy! I've had to make do with the dining room table.
trammayo
trammayo
610
71
Co. Mayo
Did I notice a change in design - from an Apex roof to a Pent roof? A great retreat anyway!
ge_rik
ge_rik
281
Cheshire
Well spotted, Mick. My original plan was for an apex, but the ridge turned out to be so high that I changed to a pent roof. As a bonus, the geometry and hence the construction ended up a lot simpler.
Rik
