Who are the Custom Model Builders of SM32 STEAM Locomotives but moved with an Electric Motor ?
N
norman
1 Jan 2013
67
5
Hello,
Thank you,
Norman
P
343
56
Not too sure what you mean. I believe Accucraft do electric versions of some of their lives steam stock
maxi-model
maxi-model
203
Bucks/Oxon/Northants area
What is it you want to have built ? Garden Railway Specialists do a number of steam outline but electricaly powered kits as well as chassis and motion sets gauged at 32 mm to put under a prototype you might have in mind. Likewise there is also a maker of a range of principally 32 mm gauge electrically powered steam outline 3D printed kits, PDF models, who might be able to ceate a bespoke design to your specification, at a price, if your desired prototype is not on their roster. Then you have got to get somebody to build it. There are a few in the UK that can offer this service, price varying on the complexity of the kit and livery required. There are even those who can supply any decaling required. However I note you seem to be the other side or the water so this might all be of little use to you but I suppose we here are the "home" of SM32.
Most 32 mm gauge lines are not suitable for DC or DCC operation and as a result their stock usually does not have insulated wheels so the above makers produce most of their models to be battery powered. Max
