Using thermoplastic for broken and missing parts
-bbbb
21 Dec 2017
437
112
Idaho
I have a playmobil 4110 gondola which was missing a door, and one hinge for that door was broken off and missing the broken bits:
I heard about thermoplastics for mold making.
So I bought some of this from Spain:
"Oyumaru" is a cheaper japanese alternative thermoplastic which comes in different colors, but I have not tested it. Both Oyumaru and Blue stuff can be reused over and over. Just put them in hot water again to make a new mold for something else. I'm not sure about Oyumaru, but Blue stuff doesn't require a mold release agent.
It was easy to make the molds of the door and hinge by warming the blue stuff in hot water for a few minutes and applying them to the good parts:
I then used Milliput epoxy putty in the door mold and on the broken hinge with the mold of the good hinge:
Milliput is easy to work with, but it's a bit brittle when cured/dried. in the next picture, you can see that the bit of the door which catches the door latch broke off as I removed it from the mold. "Green stuff" or "Procreate putty" might have been better epoxy putties to use here, since they will merely bend rather than break after they are cured/dried. Green stuff has a green finish while Procreate putty has a darkish grey finish. Milliput also comes in black as you can see with the black bits in the gondola which I've also molded ( I intended to use the black to create a caboose chimney at some point, black Milliput seems to have a smoother finish) :
if you use too much putty in the mold, you may need to clean up the sloppy results, so it's helpful that milliput is easily sanded. I've heard that Green stuff and Procreate putty don't sand as well as millliput. You can mix Milliput with Green stuff or Procreate putty to try to get the best or worst of both worlds. I think all of the epoxy putties can be added to with more epoxy putty, so I was able to fill in the chips and replace the bit that broke off of the door. I also had to drill the hole in the new hinge:
There are probably a few more touch ups I could make, and a little more sanding before I paint it, but it's nice that it was so easy to fix and replace broken and missing stuff:
I haven't yet decided what color to paint the gondola. Any suggestions?
-bbbb
21 Dec 2017
437
112
Idaho
I've decided to paint only the new parts, but the paint dried a bit darker than I expected:
I still have to re-apply the stickers, handles, and figure out how to do a peroxide/sun treatment on the door latches without removing them.
Revok
19 Jun 2018
87
124
65
West Sussex, UK
Useful info! Will give this a tryout I think.
Paradise
28 Jan 2010
1,025
251
I have ordered some 'Oyumaru' so will test it out. :nod:
korm kormsen
264
-bbbb
21 Dec 2017
437
112
Idaho
If you plan to do something like this I'd suggest watching some youtube videos on the subject. instead of tongs I used a chopstick. I just boil the water, remove from heat, and put the stuff in the water after about 30 seconds of cooling, wait a few minutes and remove with a pencil or whatever. I can handle it a few seconds after removing it. It floats. The thermoplastic can be a bit pliable even when cooled, and the item can become warped if you press the putty in so hard that it bends the mold. Some people use a frame of some sort to support the mold when stuffing the putty into it. I used a wad of tinfoil, but you can use legos, plaster, or whatever. Two part molds can be tricky because it's easy to misalign the molds and end up with one side offset from the other. Putting a few dents in the mold to align both sides with is not good enough in my opinion.
-bbbb
21 Dec 2017
437
112
Idaho
When I got the broken gondola, it came with this tipper car, with a bit broken at the lever holder, and it was missing the levers and roof:
So I added some epoxy putty, and paint to fix the broken bit, and did a peroxide/sun treatment to the yellowed handles. I happened to already have an extra roof. Special thanks to James for providing the levers:
korm kormsen
264
... Two part molds can be tricky because it's easy to misalign the molds and end up with one side offset from the other. Putting a few dents in the mold to align both sides with is not good enough in my opinion.
that is, what i am using a pencil for.
when i press the original in the first part of the mold, around the piece i push three or four holes into the mold with a pencil.
the second part of the mold gets pressed into these holes. no more offsetting that way.
-bbbb
21 Dec 2017
437
112
Idaho
That's what I was referring to. That method doesn't always work for me and others. You still have to be careful to make sure there's a solid(non-shifting) fit between the two halves of the mold. Maybe start by using the holes before focusing on how the mold fits the part?
korm kormsen
264
making the molds, first, i press the original into the first half-mold, then i push some of the mold material from all sides against the original. then i use the pencil.
then i press the edges of the second part first into the pencil holes, then i push the material from the sides towards the center, before i push downwards on the termoplast.
so i ge somewhat uneven surfaces, that help as well for a tight fitting.
i tend to believe, that mismatches and deformed copies might be often the result of too shallow molds.
as the material can be (re)used many times, thick molds are no waste of material.
but, the best molds - specially for making many copies - i made up til now are from two part epoxy, the kind used for plumbing.
that stuff gets as hard as stone (brandname: Poxilina)
-bbbb
21 Dec 2017
437
112
Idaho
Here are some video's I found helpful:
-bbbb
21 Dec 2017
437
112
Idaho
I'm using the same process to repair this broken coach, taking a mold of the good corner to duplicate onto the broken corner:
However I'm using procreate putty this time instead of milliput. it's a bit different to work with( stiff like old chewing gum, more sticky, and reacts different to water ), but isn't brittle when cured:
Paradise
28 Jan 2010
1,025
251
My 2 packs of 'Oyumaru' arrived so I put some to test. Each pack is about 2 matchboxes in volume. After being left in hot water it feels like chewing gum but not sticky then hardens as it cools to something like hard flexible silicone.
I have nothing to compare it to but it has a slight glittery pixie dust throughout which can be distracting when checking molded detail. All the colours are transparent with pixie dust.
Some softened Oyumaru was pressed over a Schleich figure bust and it kept the detail reasonably well. I then did something odd and put the mold in the freezer for a few minutes to keep hard, painted in a drop of veg oil for mold release then used the same softened substance to make a casting just for quick experiment.
It worked out OK but I intend to use something else for casting that is more suitable for carving, sanding and painting etc.
Below is not the 'Shroud of Turin' but looking into the hollow back of the mold opening with light shining behind to demonstrate how it can pick-up detail reasonably well. It's difficult to appreciate all detail as it changes on rotation when back lit. I'm sure practice can improve matters by pushing into detail areas and where the softened substance rejoins like under the cheek on RH. (The black specks are pixie dust silhouette).
253576
-bbbb
21 Dec 2017
437
112
Idaho
All of the colours you have contain glitter, or all of the colours available contain it?
Paradise
28 Jan 2010
1,025
251
Actually I'm not so sure now. :think: I have the clear glittery one. The other colours available may not be glittery but more translucent. Modern arty colours like mauve, purple, ocean green, white etc.
-bbbb
21 Dec 2017
437
112
Idaho
Same process on another coach:
Time to paint.
3,927
72
This is all very interesting as I have been dabbling with Moulding parts for a month or three now. I have not been using Re-usable Moulding Materials which appears to be the point of this thread. However what occurs to me is that 2 Part Casting Resing could have been used for many of these parts to perhaps make a stronger part.
As for making my Masters which remain Masters, I have used 2 part Mounling Compound which although quite old worked well as did the old Resin. Having used all of my stock I was given a pack of ‘Siligum’ 2 part Mould for my Birthday in May, this has proved excellent, quick and easy to use for some more parts that I was making and is now being used to bulk make Aluminium Ingots for Wagon Loads with some recently purchased 2 part Silocone.
-bbbb
21 Dec 2017
437
112
Idaho
You should share some pictures of the parts you've made. I imagine that your method would make better parts, but what I like about thermoplastic is the cost. It's cheap; you buy it once and can use it over and over. The milliput was a bit too brittle with the 2 part mixing ratio I used. But the procreate putty which I used on the coaches is not brittle at all, though the mixing ratio I used for that might have left it slightly more flexible than I'd like.
This video on different resin strengths was notable:
3,927
72
You can see some of the Barrels and Lids in this link. Post 9.
Here are some half Barrels and half Sacks with the mould. The original 1/2 Barrels were a Wood Turning on the Metal Lathe! Not very good so a commercial Barrel has been copied for the later larger ones. Note on the Sack I was a bit mean on the depth of the Master.
Finally I am also making up some Ally Ingots for loads as mentioned. Here are the two of the Masters made up from Hips and Foamboard.
Sprayed up Silver they are made up into removable Wagon Loads, this is Half a Wagon Load below. Note that I hold the Ingots in place with Flower Arranging Steel Wire pretty much as they did on the Prototype that I am copying.
Here is the latest batch of Barrels awaiting Painting and assimilating to yet another Wagon Load. The Smaller Barrels are where I was concentrating on other things and just using up the Resin Mix. Always handy to have something to use up overmix. I have now marked up an old Spray Can Lid and use this for the 50/50 Resin that I recently purchased. I just used Water in the Moulds, pouring this into the Lid and marking up the level on the outside. This method gives pretty accurate amounts when translated to the Resin Mixing.
Finally the result of Saturdays Pour into Ingot and Barrel Moulds. I had added some filler compound that Ingot with some earlier Casting Resin, this seams to expand the Mixed Resing causing the overflow that now needs to be cut off when removed from the Mould. The Brush was for Release Agent as this new Resin is trying to destroy the insides of the Moulds. To be fair to the Resin the Ingots Moulds are quite delicate in their detail.
