Tube bender: recommendations please
R
RMurphy195
2 Feb 2020
9
Birmingham, UK
Any recommendations for a tube bender please?
I'm interested in the capacity (1/8" - 3/16" OD), what radius of bend the item can make - and of course cheapness!
Many thanks - Richard
P
867
57
Copper, steel, plastic or brass tube?
1,810
72
I have 2 differing kinds both bought with a view to making pipeworks bends for live steam. Neither came with instructions and I am at a loss of how to make them work. All to do with softening the metal by heating a process that I have never understood how to do properly. Any suggestions welcome. The brass ones are regularly seen at large scale shows, not sure who sells them.
R
RMurphy195
2 Feb 2020
9
Birmingham, UK
At a guess - they look like pipe bending springs with formers. Push the spring into the pipe, bend it round the former, pull the spring back out - if you can. A miniature version of something I used many years ago when repairing some water pipes on the house, the springs were a devil of a job to get out once the pipe was bent, even when coated with WD40 first. If the bend was further down the tube than the length of the spring allowed, tying wire to the end of the spring before shoving it down the pipe was needed. Also of course the end of the pipe needs to be thoroughly deburred before using the bending spring otherwise even if you could get the spring in, you might not be able to get it back out! The technique I used was to bend the pipe a bit too far then bend it back a little, this helped to loosen the spring.
tac foley
tac foley
11 Apr 2017
2,710
733
74
Near Huntingdon, UK
RMurphy195 has it mostly right. However, there is one thing that you MUST do before trying to insert the spring into the tube - you MUST lubricate it with plumber's tallow, and I mean slather it on. That will make certain that you can remove it afterwards. Failing to do so will leave you with a piece of tubing with a spring stuck inside it.
WD40 does NOT work, trust me. It has to be a bulky lube, not something applied from an aerosol.
1,810
72
Oh I though the springy things were used the other way round! That is why they did not work. For most of my jibs they would likely be too big.
Oh Plumbers Tallow, just another glug that I must source and save!
Northsider
Northsider
3 May 2012
745
180
All tube most be annealed first: for copper, that means heating to a mid red and then letting it cool in air. Brass is not so straightforward: some is 'cold short' (i.e. snaps rather than bends when cold) while other brasses get 'hot short' (snaps when bent hot). I've never had much success when annealing brass.
I've seen it suggested that tube can be filled with sand, the ends sealed, and then the tube bent; the ends are then unsealed and the sand removed. I've not used that method, but have seen it described.
1,461
Tamworth, Staffs.
I have seen someone bend a tube, packed with sand.. It does work, but needs packing really tightly.. - So takes time to do..
The person having bent the tube successfully was not impressed, when afterwards he was informed I had the right-size bending spring, in the boot of the car! :eek::lipssealed:
LGB-Sid
LGB-Sid
19 Sep 2016
1,073
478
UK
Don't know which springs you have but there is a set that do go on the outside of the tube rather than on the inside , as I was going to buy some for bending very small bore copper pipe for model boats I used to make but never did, still not finished that boat , it's taking a lot longer than the full size one did :)
1,810
72
Well I have just needed to bend some brass tube so searched the net and yes annealing appeared to be what was needed, knew this but not how to do it! So net said heat to red then allow to cool as you say, tube never went really red but popped it into the bender when cool. Lo wow at last after many attempts a couple of neat bends. Wish the same could be said about the long one but that will be unseen. Most important thing is that where I needed the tight bends they are need and not just bent. Sorry I cannot help where these benders came from other than I previously mentioned, but they are certainly brilliant.
1,810
72
The pipe benders pictured were produced by John Angell, 16mm NGM member residing in Preston.
Aha I knew someone would advise eventually.
Greg Elmassian
Greg Elmassian
8 Mar 2014
3,932
555
San Diego
www.elmassian.com
2 kinds, the springs have the tube to be bent go inside, thus the "flared guide" at one end....
The other type has the former at the end.
Both work to avoid collapsing the tube flat when bending... the coils keep it circular and work well, the other bender will do a sharper bend, and the groove helps keep the tube from widening, going flat.
These 2 sets are not intended to be used in conjunction on the same bend, slightly different usage and results.
Reactions: tac foley
