The Build of the LIONEL 0-6-0T as the DELTON 0-4-2T .
N
norman
1 Jan 2013
80
5
2 Inch Boiler Diameter.
https://apis.mail.yahoo.com/ws/v3/mailboxes/@.id==VjN-Y_hMQSz6XfHp7JoG8C7l0uj0XZivvBQ2v-vawLImed3OUF7Or7FPTeo-SUzFLD4534NP2yLTbzZRY9HoRkJPfg/messages/@.id==AAHLm6s1P_bxXWFKwwnEACNA4cM/content/parts/@.id==8/thumbnail?appId=YMailNorrin&downloadWhenThumbnailFails=true&pid=8
1.5 Inch Boiler Diameter.
https://dl-mail.ymail.com/ws/download/mailboxes/@.id==VjN-Y_hMQSz6XfHp7JoG8C7l0uj0XZivvBQ2v-vawLImed3OUF7Or7FPTeo-SUzFLD4534NP2yLTbzZRY9HoRkJPfg/messages/@.id==AHjL7p1KfJTVXTzCEAlSuBNRqnY/content/parts/@.id==23/raw?appid=YMailNorrin&ymreqid=55cbc503-f389-182b-1cf7-11000301ed00&token=zitEzqOML3j84e6ealFTT5U7-km5qEQF52lp7AcCuBYIhO7L1H8WjmQCTG3rggQdqsJi4yRdFKfIo3m9nKe9Pg8HgeVn4dhGheScv6KYiVlK1HkYkH2Fo1uqEm0HVm75
DRIVER SPACING IS 1/2 DIAMETER OF DRIVER.
http://www.philsnarrowgauge.com/images/SP Delton Sierra Set.jpg
The IMAGES for the Build of the LIONEL 0-6-0T as the DELTON 0-4-2T .
1) PRINT LIONEL 0-6-0T AT 104%
RIGHT CLICK OUTSIDE OF IMAGE TO PRINT
LIONEL 0-6-0T
https://apis.mail.yahoo.com/ws/v3/mailboxes/@.id==VjN-Y_hMQSz6XfHp7JoG8C7l0uj0XZivvBQ2v-vawLImed3OUF7Or7FPTeo-SUzFLD4534NP2yLTbzZRY9HoRkJPfg/messages/@.id==AKeDE8pueEiCXT3G9At1mN8KX5E/content/parts/@.id==3/thumbnail?appId=YMailNorrin&downloadWhenThumbnailFails=true&pid=3
2) PRINT C P H AT 122% FOR THE CAB SIDE AND BUNKER SIDE IMAGES.
1946 Popular Science WOODEN MODEL of C P HUNTINGTON by J D W for 3.5 Inch Gauge .
http://www.vapeuretmodelesavapeur.com/telechargements5/huntington-4-2-4-jdw.pdf
3) PRINT C P H AT 103% FOR THE SAND DOME, BELL AND STEAM DOME IMAGES.
C P H SAND DOME RISER 16 MM DIA , SHRINK TO LIONEL RISER AT 13.5 MM DIA.
122% * 13.5 / 16 = 103%
The Procedure for the Build of the LIONEL 0-6-0T as the DELTON 0-4-2T .
MOVE CENTRE DRIVER AND CAB PLATFORM TO THE REAR BY 1/2 DIAMETER OF CENTRE DRIVER.
INSTALL C P H CAB SIDE.
INSTALL C P H SHORTENED LENGTH BUNKER.
RAISE CAB DECK TOP UP LEVEL WITH BOILER RUNNING BOARD BOTTOM
WHILE SLICING BASE OF CAB SIDE LOWER PANEL AND SLICING BASE OF BUNKER.
LOWER SMOKEBOX, BOILER, CAB DECK ASSEMBLY TO ORIGINAL HEIGHT OF CAB DECK.
INSTALL C P H SAND DOME, STEAM DOME AND BELL ( SCALE THE CPH SAND DOME DIAMETER TO MATCH THE LIONEL SAND DOME DIAMETER TO THEN PRINT AS AN ASSEMBLY ) .
THE DELTON 0-4-2T DIMENSIONS FROM PHIL JENSEN ,
The Cab, Cab Deck and Coal Bunker came from the C P HUNTINGTON.
The Cowcatcher and Steam Cylinders came from the Lionel 0-6-0.
Domes, headlight, smoke stack and crossheads came from the brass Delton 2-6-0.
The engine is quite small:
Over all length - 12"
Height - 5 1/4"
Cab width - 3 3/4"
Cab height - 3"
Boiler diameter 1 1/2"
Driver wheel base 2 1/2"
Driver Diameter 1 1/2"
Bill Barnwell
Bill Barnwell
30 Sep 2017
669
136
Ormond Beach, Fl
Norman, #1 are you going to make the boiler 1 1/2" or 2" if 2" plastruct has numerous diameters of tubing, if you are using the smoke box from the Lionel engine it will fit after grinding out a little of the inside plastic, make sure it fits but not to snug, mine was snug, too snug and after painting I found that the top and bottom side of the tube cracked from stress. Also if you are planning on using the Lionel drive, I don't think you will get the correct spacing on the distance between the 2 drivers and that drive unit is very unreliable, look for an LGB one if possible, I would hate for you to put that much work into it and have it not run. For the trailing truck I would either look for an LGB with power pick ups if it is going to be track powered if not any, Bachmann also makes some that are pretty inexpensive and that you can purchase on line. Rear tender section, coal/wood bunker, check around for scientific, or ezteck tenders and cut them down. Here is an attachment with some motor block sizing that might help.
Just go a hold of a rogers 2-4-2 and found that the motor blocks in it are separate so each drive wheel has it 's own self contained unit with drive wheel and was looking at something like this. Bill
N
norman
1 Jan 2013
80
5
Hi Bill,
Thank you for the information.
Norman
