scratchbuilding a first/third/parcels coach
owlpool
Welsh NG in the mountains. live steam
339
Brecon Beacons, South Wales
I previously built a 3rd on an old LGB chassis
owlpool
339
and a 1st/3rd/brake composite on a chassis of my own design
this build has been brought across to the "articles"
owlpool
339
so I wanted to have a go at something a bit different - a 1st / 3rd / parcels, a bit longer on an 8 wheel (Roundhouse) bogie chassis
the new bogies assembled, next to the previous effort
owlpool
339
cutting out the sides from 1.5 (ish) plasticard
beading applied around windows / doors
fixed using plasweld and bits of skin from the tips of my fingers :happy:
owlpool
339
slider arrangement for luggage doors
owlpool
339
door assembled - ledge brace and frame applied - planking scribes as per coach sides
owlpool
339
assembly using L cross section plastruct
owlpool
339
assembled body and roof
buffer beams built up
thin plasticard with "rivets" pushed out from behind with a tiny pozidrive screwdriver and stuck on
steps fashioned from L cross section, coach bolt heads applied
owlpool
339
bogies replaced
Accucraft choppers fitted - 1mm holes drilled - hex bolts screwed in
owlpool
339
painted and transfers applied
vacuum hoses, chains
brass handrails, handles and window bars
owlpool
339
finally - testing on the tighter point and trackwork - where Russell doesn't like to go
owlpool
339
this was not planned to be a scale model of anything - just an idea based on a number of prototypical ideas from Welsh Narrow Gauge
Produced by the NTTS Carrige Co. to a specification to meet the needs of the PDR
no copyright exists - use whatever ideas you like - I certainly did :)
Martino
380
71
Jasper, Georgia. USA
www.facebook.com
That's very good. I like that.
