Scientific train using playmobil RC car system
-bbbb
21 Dec 2017
437
112
Idaho
Interesting so what is a Xavier's 4054 as I could do with some gauges like wot you ave printed.
He sent me pictures of the gauges from his playmobil 4054 steaming mary. I edited one into this to make it more printable:
Print this image to be 3 inches wide and 1 inch tall for the gauges to be the original size.
I put a clear self-adhesive sound reducing cabinet door silencer as the lens for one(it happened to be the correct size):
iu
And I used the bogie pivot bump from an eztec gondola as the gauge wall for the other with thin clear plastic as it's lens. I put spacers inside to bring the detail closer to the lens without the image touching the lens, for the appearance of proper depth. I had to cut the bogie pivot bumps off of the eztec gondolas to fit the eztec gondolas onto playmobil frames. So they were left over scrap I didn't have the heart to throw away. It's notable that those eztec bogie pivot bumps are the exact same diameter as the round playmobil footholds molded into playmobil pirate ship decks, so you might be able to use one of those in it's place, and you can use an eztec bogie pivot bump as a foothold for playmobil figures.
Xav204
26 Jul 2017
325
417
51
Marseille FRANCE
Brilliant Brian, as usual.
Thanks for your gauges
I like the glasses in the cabin
-bbbb
21 Dec 2017
437
112
Idaho
I have been in the process of making a new bell holder for this scientific train.
I found a part from an old playmobil stage coach which seems re-purpose-able:
It looks similar in shape to the Steaming Mary bell holder, it just needs some height extension:
And a cut to fit the bell:
I removed the original scientific bell which functions as a rotatable power switch, but I wanted to keep a functional power switch there, so I replaced it with a flat blue knob which I will later paint black. I had used an old pen to make the shaft to connect to the original scientific power switch cylinder:
I still need to make the height extensions and mount it, but here's sort of what it should look like:
-bbbb
21 Dec 2017
437
112
Idaho
I found another scientific train with tender and 4 wagons for about $5 for everything:
The Scientific box car is a similar length to the playmobil box car, but a little shorter and narrower, with less standing headroom inside:
The original frame is sunken into the body which is why it's shorter than playmobil or LGB:
It's notable that the dimensions of the scientific boxcar match that of an LGB caboose frame:
But I preferred to put it on a playmobil frame, and used a wooden floor:
Replacing the floor and putting the new one flush with the bottom of the walls created more standing headroom:
The box car is more comparable to playmobil in height now that it's on the playmobil frame:
The narrowness of the scientific boxcar left a gap in the sides of the playmobil frame, so I temporarily added some electrical tape to seal it until I find a better solution:
The modified scientific train should soon be pulling the modified scientific boxcar.
playmofire
23 Oct 2010
7,257
760
North Yorks
Another bargain buy and clever adaptation, -b.
The Scientific boxcar reminds me very much of the LGB Toy Train ones in it's width.
Xav204
26 Jul 2017
325
417
51
Marseille FRANCE
I like this blue boxcar.
It is "playmo compatible".
And can be used with the yellow van without a doubt.
To change the floor was a good idea for the head of Playmobil people
-bbbb
21 Dec 2017
437
112
Idaho
Gordon, that's interesting what you say about the LGB toy train. I have not seen one in person yet. I did find an LGB caboose not too long ago, which had previously been converted into a lamp(so there's a hole in the floor which I will likely fix with epoxy. It also cost about $5. It's notable that the LGB caboose is very close to playmobil in size, much wider than it's own LGB caboose frame. Here I've placed a playmobil frame under the LGB caboose body, and on top of the LGB caboose's frame, followed by it on it's own frame:
Unlike the smaller cupolas of scientific, echo, eztec, and bachmann, the LGB cupola is nearly identical in size to the playmobil cupola:
The LGB caboose fits well on the playmobil frame, even though it's a little bit longer. It overhangs onto the step, but the tab is perfectly positioned to hold the body in place.
Here I shortened the playmobil walkway to accommodate the longer LGB caboose body:
I made some cupola seating from this playmobil pirate ship part:
I'll need to make the light boxes(from playmobil lanterns (a gold one is seen sitting on the caboose roof in a previous image)) since I don't have any LGB ones, but I may put LED's in them. And I still need to fit the exterior ladders and playmobil doors:
This modified LGB caboose may also be pulled by the modified scientific train. The scientific caboose is much smaller than this LGB or the playmobil caboose so I won't be converting that.
Xav204
26 Jul 2017
325
417
51
Marseille FRANCE
I made a lot of things with this Playmobil pirate ship part.
You are showing again this part is very helpful
-bbbb
21 Dec 2017
437
112
Idaho
Here's how the ladders ended up:
If I had more spare ladders, I might have done it differently for better rung spacing.
Xav204
26 Jul 2017
325
417
51
Marseille FRANCE
The lack of raw materials means we have to find ingenious solutions.
Bravo :clap:
The result is even more beautiful
-bbbb
21 Dec 2017
437
112
Idaho
Update:
Added a different bell holder than originally planned.
Reverted from the playmobil RC car control back to scientific controller control, so smoke unit is available for use again:
And made use of Dunnyrail's extra cattle-car steps:
Xav204
26 Jul 2017
325
417
51
Marseille FRANCE
Very nice
I like the choice of colors, which makes wonderful set
the tunnel is very nice too, and seems strongly shored,
