Replacement of Piko couplings
A
Alco K28
Guest
I recently purchased a Piko caboose, and though it would be a simple matter to swap the couplings for Bachmann knuckle couplings.
I bought a set but have found they aren’t a straight swap. On the other hand, the Bachmann couplings are a very easy swap to LGB/Peko type on their wagons/coaches.
It looks like the moulded arm from the bogie may require a little surgery/modification.
Please could someone who has converted the above share their knowledge?
Many thanks!
124
70
Many thanks!
Yes I had to carve some of the front of the Arm off, look at my Piko class 95 Battery Conversion one of the pics in post 11 shows exactly how I cut off a slice.
Piko 2-10-2 Class 95 Ref. 37230 conversion to Battery Power. - G Scale Central
Reactions: Alco K28
ARIA31
ARIA31
3 Oct 2017
109
2
69
Toulouse - France
Hi, Alco K28
If you proceed to do the modification from Piko to Bachmann couplers, please be so kind to show us some pictures.
A
Alco K28
Guest
Hi, Alco K28
Will do! I’m toying with the possibility of Kadees as well :)
