Programming MTS Locos
Dinas Bryn
13 Mar 2010
6,691
16
Evening all having another go at using LGB MTS 55015s page 60 and diagram on 61 using a track, with the set-up instead of showing C-- it showed P. How do I change this to C--? Les
whatlep
1
Worcestershire
www.facebook.com
Don't think you can mate! The software in your 55015 is an older version which shows P, not C. CVs 1 to 4 can be programmed directly: just enter the CV number when your 55015 shows P, instead of C.
Programming CVs 5 and above is a bit of a palaver: to program them needs an indirect system, which is described on 30 of the 55021 manual. You can access that from here:
http://www.champex-linden.de/lgb_pr...BBF200AAA0FEE85256BDB0057F3E1/$FILE/55021.pdf
If you can live without your 55015 for a while (typically 4-6 weeks), it's worth getting Massoth to upgrade your 55015 to parallel mode. Not particularly because of it being parallel, but programming can then be done directly to any CV and the visual indications for points and loco directions are enhanced. Cost will be around 50 Euros including return postage. If you decide to upgrade, just send direct to Massoth with a covering note. They will invoice you by e-mail and you can pay by Paypal. http://www.massoth.de/ < Link To www.massoth.de
Dinas Bryn
13 Mar 2010
6,691
16
I burnt the P version out by wireibg it the wrong way so perhaps I should send both to them Les
