I bought a wagon kit from ebay. Never again. It said "glue the end to the base. But there was nothing rigid to hold it in place while the glue set.
The kit defied superglue, extremely fast setting tough bonding glue which works perfectly well on other things. It all fell to pieces even after an hour.
So I decided to build my own wagons using alluminium. Work has held me up. The bogies need to be thought about. I can do a simple design, but I am looking for a model engineering shop that sells alluminium / copper/ brass strips, tubes etc.
i am new to G gauge, but intend to make my own points as I can get the angle right for the diverting line to save having to juggle the line to match the points.
I am considering using wood for the sleepers and I am soaking some wood in creosote for a few weeks and will let it dry so I can see if it is okay before I start laying the track. The track will be panel pinned to the sleepers. Bridges will be built in the same material. The sleepers would have to be drilled in a jig so they are all the correct width.
If anybody has any ideas I would be glad of their advice. I have some time yet as the garden is being worked on so track laying can commence in May.
