LGB MTS II Central station problem...
muns
Well-Known Member
130
Southampton, U.K.
www.gardenrailoutlet.co.uk
Does anyone know what it means when the MTS II (55005) flashes the left LED (RED) alternatly with the right LED (YELLOW) as I cant seem to find that sequence listed in the manual?
I havnt used it for ages and this is occuring straight away from power up.
don9GLC
1
Aberdeen
I don't have any experience with the MTS II system but the manual I downloaded from
http://www.champex-linden.de/download_lgb_bedienungsanleitungen/55005.pdf
states on page 14 and also page 23 that the left red flashing led indicates a short circuit.
Its not clear but page 17 suggests that a right yellow led indicates analog operation but page 18 suggests that the right flashing led means the system has a train mouse connected
Page 20 states that any previous operating mode will be retained after the central station is reset.
Hope this helps. I would suggest disconnecting the Central Station from the track and clearing the fault indications before looking for any faults on the track. If you have not used it for 'ages' it may be damp or failed :( I hope not, but it sounds ominous. Certainly worth keeping it in a heated environment to warm up for a day if it has been in cold or damp storage.
Don
muns
Well-Known Member
130
Southampton, U.K.
Thanks Don,
(I had all of that information)
I forgot to mention that the flashing sequence is occuring when the central station is NOT connected to the track and that the universal handset is not eluminated in any way.
Personally, I think the unit wants a one way trip to the electronic recycling center!
In any case, I have posed the question to the guys at Massoth, both on their forum and via email.
laney
Model Rail
2 Feb 2010
134
Welsh Valleys, near Newport
This may be the usual problem with condensation that the LGB unit suffers from.
Where have you been keeping it? Learnt a lesson with mine and now bring it back into the house every time I finish.
Mine had the condensation problem but thankfully responded to nice warm air from a heater overnight.
KeithT
190
Nr Manchester
Mark
Does it happen when the power is on but nothing connected?
I have what appears to be a faulty remote - probably the cable. This gives similar fault signals from the green/red lights.
The main unit is fine until the remote is plugged-in.
KeithT
190
Nr Manchester
Oops - Deleted
Managed to reply to my own message when all I wanted to do was edit it......:wits:
muns
Well-Known Member
130
Southampton, U.K.
It has been kept indoors.
It still occurs when no handset is connected (i.e only the 2 wired from the transformer connected).
whatlep
1
Worcestershire
www.facebook.com
There is an internal fault on the circuit board. Try keeping it warm, but powered off for a while so any condensation gets a chance to go away. If it's still playing up, it's say hello to Mr Repair Man at Massoth.
muns
Well-Known Member
130
Southampton, U.K.
I have had an email response from Massoth:
Alternate flashing of both LED's indicates an issue with the LGB-Bus. Normally it is a "short circuit" on the bus. This is not detailed in the LGB manual.
Now, how do we open the dam thing up......any ideas?
whatlep
1
Worcestershire
www.facebook.com
It's surprisingly easy. The red circular things on each side of the housing are push fit lugs which hold housing and base together. If you have a bradawl or something similar with a slim, sharp point, you should be able to lever them out. Once done, the housing will simply lift off the base. Be aware that by doing this, you'll leave tell-tale traces on the lugs, so any warranty claim may be invalidated.
Reassembly is just mating the bits of plastic and push the lugs back in until they lock.
stockers
3,795
65
Nr. Ashford, Kent. England.
Well done to Massoth - a nice quick answer.:D
