Hello Fellow LGB Trains Hobbyists - If you're thinking of buying the newly produced and beautiful LGB 20283 Mogul Steamer, you'll probably need to add some weights to the engine to improve its traction/pulling power. See my email to Marklin/LGB Service Department below.
"Hello Marklin/LGB Customer Service – A long-standing customer of mine who recently bought from me an LGB 20283 Mogul says that the locomotive has poor traction/pulling power with 4-axle LGB passenger train cars using metal wheels……..the locomotive’s wheels spin in-place when starting to move, and sometimes the locomotive derails on track curves.
The approximate weight of all LGB Mogul locomotives produced since 1985, such as the LGB 29182 Mogul locomotive, is 7 pounds My customer weighed the LGB 20283 locomotive and it’s only 5 pounds. So it’s highly likely the LGB 20283 is seriously unweight and that’s causing the poor traction and pulling power of the locomotive. The metal weight in the LGB 20283 locomotive’s front smokebox/boiler has been reduced to make space for the installed pulsed smoker, but that removed material has not been repositioned within the smokebox/boiler. Additionally, the metal material now used in all LGB locomotives weighs less than lead material previously used. As a result, the LGB 20283 locomotive weighs 2 pounds less than older LGB Moguls, and this weight loss is causing the traction/pulling power problem.
Recommendation: The metal weight in the LGB 20283 and future LGB Mogul products needs to be redesigned to increase the weight back to 7 pounds so the locomotive will have adequate traction/pulling power. And the redesigned Mogul weight should be produced ASAP and placed into Marklin’s LGB Parts Inventory System so that LGB Service Centers and LGB hobbyists can order replacement weights for correcting the LGB 20283 Mogul locomotive’s traction/pulling power deficiency. This is an important quality improvement action required to ensure LGB locomotives will continue their high reliability reputation and purchase and use by large G scale trains hobbyists."
Thomas White
Old Dominion Railways - LGB Trains
McLean VA USA
Thomas White
McLean VA USA
1
- Show all
