LGB 12040 Switch Lantern.
hornbeam
1,881
I have a few of these to fit. It maybe me.... but is driving me mad- I cant get them to work!!! ANybody got them and if so any fitting tips?
Thanks
LTfan
2
Try this:-
http://www.onlytrains.com/model/railroad/WLGB.html
Go down to this item:- Explore The World Of LGB 00559
On page 102 is a reference to 12040 needing a source of power to operate the light inside the lantern.
Hope this helps?
WillemD
35
Belgium
hornbeam - 8/11/2009 9:24 PM
Thanks
You mean the little lamp doesn't work? Or if it doesn't get fitted well so the lanterns won't move either...
Well, I have the same problem.. I can't get it fitted in the right way so the lantern turns with the switch.. Have tried this a million times.. :wits:
hornbeam
1,881
cheers folks, can get the latern to work but not move. Glad someone else has this prob- Thought it was just me.
dutchelm
176
N Somerset
I've got fed up wih cleaning them & making them work. The point motor wasn't man enough to throw the point, change over the aux switch and turn the light. Took them off with the exception of one important one. I have added a second point motor on the other side to provide more push.
Andrew WH
Preston
Hi
I have found that i need to put a small drop of oil (I use the LGB stuff). Then the things have worked a treat for me. Normally need just a drop of oil at the begining of the running season.
Andrew
palmerston
trains
14
Netherlands, near Aachen ;-)
Indeed i have done away with them. Lubrication the moving bit doesn't help either. They make your switching operations totally unrealizable. The LGB point motor is very week hence it cant take any extra load. Indoor use only then.
The Devonian
17 Nov 2009
1,966
23
South Hams
<p><font color="#0000cc"><font size="3"><font face="georgia,palatino">Having laid Aristo brass (USA style) track with manual switches/point (10') I noticed that the small lanterns on a couple of the switches were missing. It transpired that my dog, when chasing unwanted gulls, cats etc. was knocking them off as she raced around the garden. I retrieved them from the dirt and decided not to re-install them. :rolleyes: </font></font></font></p><p><font color="#0000cc"><font size="3"><font face="georgia,palatino"> I have since used them as marker lamps on scratch built cabooses and combines.
Gizzy
36,149
2,278
63
Cambridgeshire
I have a couple of these and I've had no problems with operating them. One is on the crossover below, which gives access to the 'Quarry Branch' or put another way, the continuous circuit on the Logs, Gravel & Bricks.
The lamp housing will only fit on one way, and it has a 'key' so you can't fit it 'back to front'.
I haven't as yet powered the lamp, as I didn't want too many wires around.
I have painted the arrow in green and the circle in red on mine.
I find them useful as I can see from the controller in the 'Signal Cabin' (i.e. the shed!) the route set
Gizzy
36,149
2,278
63
Cambridgeshire
The other switch lantern can be seen on the point furthest left here, at Weybourne North Junction....
minimans
Trains, Planes, Automobiles & Shooting
222
67
San Francisco Bay Area
I tried using these many years ago with my automatic EPL set up but the failure to fully change the point was unaccepable even with a 24V 5amp supply! so I gave up on them. I still have a box of parts somewhere......................
spurs123
led zep spurs lgb
st albans
I have a few on the layout and have had no problem with the point switching only the bulbs working loose but again all mine are inside safe and warm.
