I'm installing an ESU LokSound 5 XL DCC Sound/Power Decoder into a friends LGB 2018D Mogul and discovered the two lead weights are missing. I assumed the original owner must have removed them until I consulted with Klaus Stork here in the USA who used to work for the original Erst Paul Lehmann Patentwerk as a technical adviser in Germany for many years. He told me that some of the original 2018Ds were manufactured during 1985 - 1987 without the weights. These weights obviously help with traction and stability and keeping the front leading wheel on the track, so I tried to find some used ones and my Massoth supplier in Germany even checked with Marklin for spares to buy.......no joy! So, my friend and I decided to manufacture our own replacement weights using molds and melted lead. I'm now selling them on eBay.com and my own Website if anyone needs a set. I sold a set yesterday to a person who needed them for the rebuild of his LGB 2019 Mogul's motor block which apparently didn't have them installed either. LGB installed weights into their follow-on Mogul models, so this issue applies primarily to the 2018D model.
As a side note, the LGB lead weights can start to develop corrosion which can flack off into the motor block and clog the gears, and this occurred with the used 2018D I'm working on. It was such a mess I had to completely clean out the motor block and even replace the idler gears. Then I've spray coated the new weights with Garder Bender Spray Liquid Tape, a rubber formula coating, to prevent any future corrosion in the motor block. If you operate your layout on the sea coast, you're probably more likely to get this lead corrosion. Just sharing some recent experiences with you.
