Re:Help required current reverser for a very small test track.
Kaine said:
ntpntpntp said:
I have to agree, I wouldn't recommend any sort of "simple" device that simply switches from one direction to the other with slowing and stopping in between: it's not good for the loco mechanism.
Now I can't follow so good.
If I use a switcher in the yard to switch boxcars I have to go back and forth and pick up speed and slow down to a halt after coupling.
Is this not good for the mechanism?
I would not like to ruin my motors, but never heard of this before.
I am not that good at electrics, so would very much appreciate a little bit of info on the matter.
Thanks,
Eric
Hello Eric,
I wish the simple questions had simple answers!
Every time you use your locos you are causing wear, so that is 'not good for the mechanism'. But its no fun, if you just leave them in the boxes
If you are switching boxcars in the yard, you will be controlling the loco to go slowly and not crash into the cars, so the mechanical load on the loco is not high. That is not likely to give you any problems.
However if you use a cheap method of reversing, the loco will be switched from high speed in one direction to high speed in the opposite direction almost instantly. Its the sudden change that puts load on the loco mechanism and is bad for it, and the wheels. Full size trains get flat tires too! A long time ago that was my job. It usually happened when the crew forgot to release the parking brake on a 'control car' (we called them a driving trailer in the UK, but you might be more familiar with the LGB / Swiss expression)
The LGB module 10340 has three connection possibilities. Mode 1 (basic) has an abrupt stop and I would not use this for your tram. Mode 2 (prototypical) is better since there is a 'braking' phase. The third connection possibility is the one I would recommend and has an extra track section for safety. If your tram overshoots and enters the extra track section it will stop abruptly, but this is not likely to happen normally (because you will have set up the unit correctly
) and it is better than a crash at the end of the track!
I hope this explains the problems but please feel free to PM me if I have not explained them clearly enough.
Don
