Hi all, hoping that someone out there can help with a slightly odd question.....
I have an LGB 23593 Class 2092 diesel, which came factory-MTS-fitted. Some while ago I decided to add sound via an LS chip (removing and replacing the original MTS decoder completely), and got the project half-finished when I got distracted on other things (ooh, shiny....). I've now decided that with the imminent release (hopefully) of Massoth's new "S" sound module, it would make much more sense to fit one of those as soon as they become available, and re-use the LS in something else. So..... I need to put the old MTS factory decoder BACK into the 2092.... I have all the bits (I deliberately didn't cut or damage anything when I removed it, just unplugged and unscrewed everything) BUT I need to know which plug goes into which socket on the factory-fit decoder!
Yes, I know I should have taken a photo first, but I didn't.... hindsight is always 20/20....
The plug from the motor/pickup harness is still connected to the board, so that bit is OK - but there is the other 4-pin large plug from the cab control switch, and a choice of 3 sockets for it to go into (one RED socket, two black), and five little two-pin plugs from the lights (3 at the front, 1 rear plus cab light) with a multitude of possible two-pin sockets on the board.
Does anyone have (or know where I could find on the interweb) a photo of this loco (or a similar one with the same type of decoder) showing the standard factory decoder installation? Or an exploded diagram showing where each plug goes?
Any help or constructive suggestions (apart from "take flippin' photos next time!") from the Gestalt Listmind would be very gratefully received.....
