G scale signals
S
Simon Potter
Srpott40
14 Jun 2016
38
Dorset
apologies if this has been discussed on another thread.
Does anybody know where I can buy, G scale signals at a reasonable price, (after at least 10 of them). My only specifications are that they weather proof, and can be changed using a switch somehow. (So they can be operated in the same place, from my control panel.
Any ideas would be very much appreciated
idlemarvel
idlemarvel
Neither idle nor a marvel
13 Jul 2015
2,169
307
Ascot
There are also colour signals (gauge 1) from Maerklin and GSSB also but they are all German or Swiss apart from the LGB US semaphore. None of them I would call cheap. If you want cheap you have to build your own. What type and country of signals are you after?
Gizzy
Gizzy
33,353
842
59
Cambridgeshire
1,828
72
I have used both Playmobil and scratch built sigs by Andy Rush. The Playmobil ones are repainted, all my Sigs are Air Ooerated. Some pics of mine on the line seen in my Build Thread:-
A new Railway is Started - G Scale Central
Post 96 shows examples of both.
Andy used Tops from Photo Slide Canisters for the Round Ones, but I guess that any Pill Top would work. The smaller Shunt Signals are those iritating Circles that have to be popped out of Metal Plug Wall Mounting Socket Boxes.
You could look at Glendale Junction who have a rather nice line in Electric Light Signals, made by a tame local they are very reasonable price and look very good. I have used some of the Shunt Signals in my Garden.
Gizzy
Gizzy
33,353
842
59
Cambridgeshire
You could look at Glendale Junction who have a rather nice line in Electric Light Signals, made by a tame local they are vert reasonable price and look very good. I have used some of the Shunt Signals in my Garden.
Yes JD, I too have used the double red ones for the buffer stops on Hardyard.
They are apparently O scale but work well enough?
Hardyard also has some colour light signals brought from a member of this forum, but I am not sure of their provenance....
James Day
James Day
Guano Corner Rly - Runs weekly - Guano permitting
6 May 2012
1,727
3
Warwickshire
I too use converted Playmobil Colour light signals. They keep the weather out well! I have nine which have been out in my garden for four years now. The only parts that need replacing are the white edging of the target board around the lenses, which is paper, and eventually fails!
The paper on this one needs replacing!
I run them on an 18v AC supply, the switching is provided by a LGB EPL drive which I mount them on, this also switches the power to the isolated sections. I use the older large 1203 type add on switch rather than the modern small 12070 type, and mount the signal to this with hot melt glue! A Playmobil buffer is mounted on top of each signal to keep the wet out of the recess for the switch that it comes supplied with, but has been removed.
This one has had the paper replaced with Varnished masking tape!
They cost around £10 each when new and are a very robust and cheap solution. Even when one of my nephews knocks one over when he plays football in our garden, the worst that needs fixing is that the signal needs re-glueing to the LGB switch unit.
PS - I like the Marklin battery operated signal is Gizzy's posting. That looks like it could be adapted in much the same way as the PM ones. It looks a little neater that the PM one, but it would be interesting to see how big it is and how weatherproof it can be.
PPS - Just found this image of Gizy's signal: http://www.johanvoermans.nl/index.php?act=viewProd&productId=5750
Sadly it appears to be a little on the small side. That appears to be HO track! Pity!
James
P
playmofire
23 Oct 2010
6,970
295
North Yorks
Yes, I think it is HO; certainly the link Gizzy gave had HO in it.
Gizzy
Gizzy
33,353
842
59
Cambridgeshire
It is an HO toy signal but it is very over scale.
More like O scale.
I thought that it could still be used on a platform or similar.
I brought one recently to experiment with so I will have a measure and post pix at some point....
S
Simon Potter
Srpott40
14 Jun 2016
38
Dorset
Thanks everyone for your input on this thread, the main thing i have spotted is that there is no main type of signal that everybody uses!!
So think I will need to have a go myself, in my workshop!!
S
Simon Potter
Srpott40
14 Jun 2016
38
Dorset
Is Hardyard an outside layout, as I've looked into these in the past but been told they are not suitable for outside use
1,828
72
My 4 Shunt Signals x Glendale have been outside for over a Year now and are just fine still.
Zerogee
Zerogee
Clencher's Bogleman
203
North Essex
Gizzy's "Hardyard" is a VERY small indoor show layout, a little station yard with a single R1 point and a sector plate in a hidden fiddle yard - but it's amazing just how much fun you can have just moving a couple of short wagons around on three tracks with a single loco! :rofl:
minimans
minimans
Trains, Planes, Automobiles & Shooting
4
63
San Francisco Bay Area
I converted LGB signals to sort of British outline , I no longer have a railway so they are surplus to my needs right now. If your interested in them just drop me a PM
Gizzy
Gizzy
33,353
842
59
Cambridgeshire
Hullo Simon,
Hardyard is a small indoor layout. You can find out more about it on this thread here;
https://www.gscalecentral.net/threads/hardyard-a-g-scale-indoor-layout.51853/page-8#post-427267
However, I am surprised that you have been told that they are not suitable of outdoors?
I know that these signals are used outside on Glendale Junction's layout, and a friend of mine near Cambridge has also used these outdoors. The bias resistor is protected from the elements with heat-shrink sleeving but addition protection wouldn't go amiss....
H
Herman Beals
9 Nov 2019
2
Freeville, NY, United States
PPS - Just found this image of Gizy's signal: Johan Voermans
James
Helo. In June 2016 you posted that you converted a signal using an Lgb device. I am trying to do the same, so I would greatly appreciate it if you could post the electric diagram you used. Herman Beals
The Tinker
The Tinker
Every day I wake up is a good day
6 Feb 2014
281
12
Whangamata New Zealand
Roundhouse sell a resonably priced kit
P
Paradise
28 Jan 2010
994
223
Another option is the LGB 5030 Bavarian signal. They are relatively inexpensive, unpowered but could be modified. Easily lit. Upper quadrant.
