G Scale railway indoors
GAP
GAP
G Scale trains, Lawn Bowls.
14 Jun 2011
2,477
48
65
Any chance of some pictures of your layout please?
Second that request many pictures from every angle I have a huge hard drive (1TB) for pictures and want to fill it up.
The more detail the better.
R
Robert shufflebotham
9 Nov 2017
7
Welch oklahoma
korm kormsen
korm kormsen
33
Robert, that didn't work. give it another try, please.
AppleYankee
AppleYankee
25 Nov 2016
19
Maine, USA
My indoor layout is 11 X 26 ft, 48 in high and 30 to 36 in wide.
GAP
GAP
14 Jun 2011
2,477
48
65
Thanks for the pictures, please send more, the more ideas the better any thing to keep me occupied for the next 18 months till I retire.
Love the avatar, reminds me of what I used to work around back in the day.
idlemarvel
idlemarvel
13 Jul 2015
1,828
165
Ascot
Nice and tidy well organised layout. Quite a few crocs you've got there! Thanks for posting.
mike
mike
Moderator
904
Rossendale
www.lazygrangebay.co.uk
Looking forward to seeing what you build..if reach is a problem from the front . May be build away from the wall.ie a space for you to get to to reach from both sides
korm kormsen
korm kormsen
33
....if reach is a problem from the front . May be build away from the wall.ie a space for you to get to to reach from both sides
my last layout had an access of 40cm/16" between wall and layout.
that was handy, while i were slim - today i would need a "slightly" wider space.
659
Tamworth, Staffs.
Errrrrr!
Just what is that character in the foreground supposed to be doing?? :eek::tmi::tmi:
stockers
stockers
81
Nr. Ashford, Kent. England.
Dead lifting a bloody great plank of course.
Reactions: mike
ARIA31
ARIA31
3 Oct 2017
130
9
70
Toulouse - France
Gap, for the time remaining until you starts your railroad, I would suggest you buy one of the proposed softwares to design your railroad.
I personnally use Anyrail.
I have a much smaller railroad than yours but I spent a lot of time to design the modifications I am currently implementing.
And this is a helpful tool well suited for size G.
You get detailed list of hardware needed , circuit length , 3D pictures.....
This is useful as well for cost optimization (if needed to you !)
AppleYankee
AppleYankee
25 Nov 2016
19
Maine, USA
korm kormsen
korm kormsen
33
laying some landmines, perhaps?
Reactions: trammayo
AppleYankee
AppleYankee
25 Nov 2016
19
Maine, USA
I’ve been using “RR Track” to design my track work. The only glitch that I have found is that the software does “G” at 1.24. The track plan shown fits in my 11 X 26 ft space. There is a 22 in space between the wall and the back of the layout.
stockers
stockers
81
I lay track by adding what ever fits next. I build the base work to suit. I do enjoy mucking around with these software packages but in the real world - I just cut and fit to close the loop. Bit different in a confined space, I agree.
598
71
Actually if you can manage to build the baseboards pre layout build you can play around with different track layouts as time allows. We found this method worked very well on the Ruschbahn with 3 or 4 iterations of both the Station and Low Level Fiddle Yard before a happy compromise was reached. Would certainly suggest no baseboards much wider than 30 inches unless acess is available both sides then keep the 30 inch Block rule unless you intend to do some Pop Ups for access. However walk around and the narrower boards will stay the test of time as you grow older.
stockers
stockers
81
Base boards?
