FlySky RC problem
MRail
16mm etc - Live steam, battery & trams
3,365
37
Merseyside, U.K.
youtube.com.user.MadogMersey
Wondering if anyone has had problems with FlySky 2.4GHz equipment.
I bought 2 sets a while ago via eBay and fitted them to identical tram locos based on Lehmann Porter mechanisms and with 8 x AA alkalines = 12V. Control with a Turnigy ESC.
They don't see a great deal of use, but one Rx has recently started to lose contact with its Tx.
The motor runs for about 30 secs then stops, and the Rx led is flashing, as though it's searching for a signal.
Switch everything off for a few seconds, then it will start again with the same result.
I've not yet contacted the seller.
Thing is, at the price of £17.50 it's doubtful economics to post it back to China.
Any tips? (I know - buy cheap buy twice)
Del Tapparo
24 Nov 2009
196
1
Windsor, Colorado, USA
www.gscalegraphics.net
You may have a problem with the ESC. Most Rx LEDs flash like that when they lose power and then it is restored.
MRail
3,365
37
Merseyside, U.K.
Del,
Thanks for the hint...
I removed Rx from tram, and refitted Zebra 40MHz kit. Tram now works OK.
Using separate battery & servo still has problem with FlySky.
I guess I could look for a Rx.
Rob G
minimans
Trains, Planes, Automobiles & Shooting
222
67
San Francisco Bay Area
Theres been a lot of talk on the R/C Airplane forums about Rx dropping out (Bit more serious in a $5,000 dollar jet) the consensus seems to be that the servo's take a lot more current than the old one's and that leaves not enough current so the RX drops out, some people have upped the battery voltage and the problem goes away but all the Suppliers deny that this is the problem. seem's like spectrum seem to be getting the most complaints?
MRail
3,365
37
Merseyside, U.K.
This one seems to be a Tx problem, since the Rx works OK with the other Tx.
Vendor has offered to replace it, if I post back to Hong Kong.
Now checking costs!
The theory of relativity enters the building.
bobg
3 May 2010
20,141
25
Middle Earth
Interesting thread! My Countess came ready fitted with a Spectrum DX6i, so not my choice. I have inadvertently run the Rx pack down right down on one occasion, and the problem showed up as the regulator channel dropping out and the control remaining with Fwd & Rev channel. I'm certainly not an expert in this modern stuff, nor any previous (I count my time back to carrier wave, but purely as a user), but surely running the batt pack to near to flat will reduce the voltage available and the Rx did not drop out before one servo. Quite obviously everything must have been getting pretty marginal.
Budd
4 Nov 2009
57
Adelaide, down in Oar-Stralia
What are you using for reversing current after the ESC? or are limited to one direction only?
MRail
3,365
37
Merseyside, U.K.
Sorry for the long delay...
Reversing is by a servo on the other channel, operating a DPDT switch.
I've since posted the FlySky back to HK and a replacement is on its way.
Budd
4 Nov 2009
57
I am using the same system but with a Hobby King 2.4 radio and 10 x Turnigy AA rechargeable's = about 13V, Have squeezed it all into an Eggliner for the grandson. I am curious though, my reversing servo chatters a lot, I had to file out the yoke so it wouldn't accidently flip the reverse switch over, I am surprised and annoyed that the servo does this, anybody else experience this or have a solution?
MRail
3,365
37
Merseyside, U.K.
Yes - my servo chattters a good deal.
It can be stopped by adjusting the trim, but starts again after being moved in the opposite direction.
This process can go on indefinitely.
I'm learning to ignore it.
