Digital Mysteries! Control (or lack of it) via Track Contacts
minimans
minimans
Trains, Planes, Automobiles & Shooting
3
62
San Francisco Bay Area
The magnets in the motors are tripping the contacts you need to lower the contacts away from the track this will mean not using the supplied mount's.
P
Philbahn
Swinton Manchester
Roland is the reed switch picking up off the motor magnetic field.
Are they standard reed switches(LGB) or the massoth ones
P
Philbahn
Swinton Manchester
LGB 17100 I think.
The reed switch on 3a must be picking up from the motor mag fields.
Even tried shielding one using a strip of vinyl flooring but it still stopped.
Just thinking aloud have you bridged the two diodes?
Neil Robinson
Neil Robinson
47
N W Leicestershire
Personally I would disconnect the wires from the reed and alternatively, as a motor unit passes the reed, leave the wires open circuit and then next time momentarily short them together . Dependant on the results you will know if it's the reed or program that needs working on.
P
Philbahn
Swinton Manchester
Roland just a queery. What are you trying to do with the switches. Can you explain in a bit morre detail.
P
Philbahn
Swinton Manchester
Pleased you have it working Roland
