Having now got some of the Chinese made wagons "in stock" for kitbashing, the weather today (here anyway..) enabled a start to be made on some rebuilding work.
I was initially looking at the possibility of splicing two of the box vans together to make a longer wagon, and then mounting it on one of the bogie chassis. This appears quite feasable, but at the current pricing, is rather more expensive than it would have been a few months ago!
On one of the other threads, someone mentioned removing the end platform, so this was the logical first version to produce......
Seperating the body from the chassis is easy - remove a pair of steps and then unscrew 4 screws - the chassis then comes away from the body.
The end where the platform was obviously lacks a buffer beam, so it was a case of raiding the plasticard supply for a suitable piece of material to cut to size and then fit.
The chassis then had the platform end cut away from it, but it still needs about 5mm to be cut off the end so it fits under the body - something that will be done once the new buffer beam has dried. Remember - You can't shorten the chassis at the other end as it will mess up the positioning of the sliding door runners!
More updates to follow as the work progresses...........
(will try bigger pictures next time.....and I know how to put them in with the text now!)
