An overview of the results of the survey about battery power and charging - https://riksrailway.blogspot.com/2022/05/battery-powered-locos-survey-interim.html
Rik
Rik
2
- Show all
Pretty interesting. I wonder how many people have more than one charger because they charge multiple locos at once, vs having different chargers for different battery chemistries?An overview of the results of the survey about battery power and charging - https://riksrailway.blogspot.com/2022/05/battery-powered-locos-survey-interim.html
Rik
I'm compiling a follow-up survey so I could try to ascertain that - if I can find a way of phrasing it.Pretty interesting. I wonder how many people have more than one charger because they charge multiple locos at once, vs having different chargers for different battery chemistries?
Something that would be fun to know is how many kilometres everyone's locos do in an average running session, and with what sort of loads. I don't even really know the answer for myself, I'll have to build a dynamometer car and do some tests.
Whilst I could work out the loco distance traveled (in scale km’s) on each of the 3 workings, adding shunting to that is pretty well impossible as each session has different complexities with the shunting requirements. Hm tricky.I'm compiling a follow-up survey so I could try to ascertain that - if I can find a way of phrasing it.
It would be interesting to find out distances travelled, but I suspect very few of us would know. Sounds like another project ,,,,,,,
Rik
Another day, another survey. Completed.As a follow-up to my previous survey which was focused very much on a specific issue - a few people asked if I could make a more generalised survey as a follow-up. Well here it is.
Battery powered loco survey Part 2
A survey for garden railway modellers about battery power for locosforms.gle
Rik
That's a fair point. Generally, with shorter trains (although US outline) I get 3 - 4 hrs using NiMh (if I can be bothered to try for that longKnow that most people in the US run much longer trains that the average presented on this forum.
You FoolI have had both chargers for about 6 years and they have never let me down......... oh dear, why did I say that!!!!!!!?
Yep, I started with NiMh and have, so far, not moved to Lithium based because I didn't think I'd sensibly manage the two different charging regimes.I have 7+ locos the majority steam outline, (2 small diesel) with a mix of Li chemistry batteries and NiMH chemistry.
I own 4 chargers 2 which I bought and 2 which I inherited. 2 are set for NiMH charging and 2 are set for Li charging.
I do not get the length of run time out of the NiMH as I do out of LI (x).
I am in the process of changing the NiMH out for Li-ion as they fail and they will fail as they are nearly 15 years old (1 so far).
I've now standardised on li-ions but when I had a mix of NiMh and li-ion, I wrote what was in the loco on its underside using one of those gold marker pens. Although I also kept (and still do) a booklet with sections for each loco logging what it's equipped with, any changes/repairs/maintenance and each time I charge it (inc. start voltage), it's handy to make sure just before setting up the charger. Mind you, the iMaxB6 is very good at sensing what pack is in the loco - but even then it's not foolproof.Yep, I started with NiMh and have, so far, not moved to Lithium based because I didn't think I'd sensibly manage the two different charging regimes.
If I wrote everything down, such as which loco uses which charger (oh, and which R/C handset) then it probably shouldn't present a problem, but that's a big 'if' .............. I'm not that organised.
However, for some strange reason, I can remember the voltage of the battery pack inside each locoand there's quite a variety
I too have specific Txs for specific locos - and have them listed on a sticker on the back of the Tx. However, it's so easy to rebind a loco a a different Tx (or Selecta channel), I sometimes swap them about a bit - especially if I decide to run a couple of locos which have been bound to the same Tx.I only use NiMh batteries for my locos. I too worry about the care needed, and the expence of, more specialsed chargers for the more energy dense battery technologies that are now starting to prevail throughout the hobby world. If it meets my needs I do not see the need to change. Hence my love of the old Sierra sound cards, even now. When I (on very rare occaisions) run track power,I use my old Train Engineer set up. Live steam, where supplied for original RC equipment like TX's, I use non-rechargable - they last a very long time in that application.
Where I have converted a loco from track power to Battery/RC, I have a rough rule of 1TX to 3 locos. I label the TX's identifying which loco is bound to which TX. I try to mix up the loco types on one TX so that there is the maximum opportunity of running like with like during a session. E.G. On one TX there will be a a geared logging loco, a passenger Mikado and an "oddball" like a little Porter or a diminutive Victorian ten wheeler.
I should admit now how I am a convert the DCC track power.......but that is only with my nacent indoor 009 NG layout. For me the benefits are very obvious, especially if you have sound fitted to a loco. Funny how we arrive at our particular preferred methods of operation. Horses for courses, as they say. Max
I actually have two chargers (both iMax B6s) but generally only use one of them and keep the other as a spare. I suppose I could use the second to charge up a second loco, but I've got into the habit of just using one. I keep a log of which loco was charged when - but in addition when a loco has been charged it sits on the shelf facing forwards - and when I return a loco to the shelf which has just been run, I face it inwards. That way, whenever I decide to run some trains I just take forwards-facing locos off the shelf.I have 7+ locos the majority steam outline, (2 small diesel) with a mix of Li chemistry batteries and NiMH chemistry.
The way I manage my locos is similar to the way the 1:1 railway that I volunteer at.
We run the locos on fare carrying days (an operating session) the the day after we clean the boiler tubes, grease the rods, top up the coal bunkers and perform water quality checks after filling the tanks.
I run my locos for the operating session and the next day I charge any batteries that require it. As my locos do not need all that much attention the act of charging batteries I treat as a maintenance day.
Having 4 chargers available in my charging area allows me to service all my locos at once.
When I first started I went straight for the battery option (mostly because I had seen it demonstrated and recollections of cleaning the track continuously on my HO layout) and only had 1 charger.
I personally prefer battery as I do not have the hassle of running cables across my yard and I can bring out a loco at a moments notice and set it running and not have to worry about dirty track or faulty joiners.
Finally people can write battery charging into their operation narrative which ever way it pleases them as I did as a maintenance function.
