Chris M said:
Re wiring to allow isolation of tracks.
The simplest way is shown here -
http://www.gscalecentral.net/m41159
A more complicated/ expensive solution is here -
http://www.gscalecentral.net/m22754
If any mods read this is there a place where reference information like this could be kept? This particular question does keep cropping up.
Hi '
5H17' I used part of Chris's diagrams shown in these posts to set up my little lay out when i first started out (and knew even less about trains than my Gran did),
and it works a treat, So thank you Chris M for posting it
I now have a lot more track and it covers a much bigger area and it still works,
I would like to use something similar to the bottom half of the diagram shown in m22754 to automate a few of the more remote points.
The diagram is very simple and easy to follow (thanks again for that Chris) but in it you show a point controller that is controlled by the ABCDE buttons on the Train enginer
( I assume ).
My question is what is the 'Point Controller' ?? I think i have all the other parts needed but am not sure what i need to use as the 'PC'.
My apologies in advance to '
5H17' if this is a bit of a thread hi-jack
Any advice would be most appreciated
