a problem with eMotion XLS
French Chuffed
South Brittany
I have a 99-6001 HSB sound decoder fitted in an LGB 2 6 2 loco. It has run successfully in the past, but now when you apply full speed the loco speeds up for about 3 feet then stops, then starts up again, doing this repeatedly. I haven?t altered any of the cv?s from the previous running. I am using an LGB mts2 and LGB hand controller. Any suggestions would be helpful
Steve
I didn’t say it was your fault, I said I was b
1 Jan 1970
29,027
285
D.I.L.L.I.G.A.F
Do you have a way of checking the voltage the motors are taking sound like a iffy motor
Philbahn
3
74
Swinton Manchester
I agree with Steve. Think I would check the motor out.
These motors seem to start & stop when they are tired.
muns
Well-Known Member
130
Southampton, U.K.
www.gardenrailoutlet.co.uk
Sounds to me that the decoder is shutting down due to overload, reseting itself, and going again....
Can you measure the current draw of the motor?
mike
Master at annoying..
4,444
Rossendale
its sounds like as mums surgest, over load on the chip. ive had v52 do exzactly the same.. it was a worn out motor
French Chuffed
South Brittany
Sounds a good possibility, I will put a meter on it tomorrow. What sort of current should it be drawing?
Thanks chaps.
Philbahn
3
74
Swinton Manchester
Thibk if you remove the motor and wire it on analogue and let it run you will find that it starts and stops/ Hope this helps
mike
4,444
Rossendale
Thanks chaps.
0.5 amps, to 0.75 is normal, 1 starting to wear.., 3 will trip the decoda..
Neil Robinson
579
N W Leicestershire
Thanks chaps.
A good motor running light when removed from the loco with usually draw between 0.1 and 0.2A at approx. 20V.
French Chuffed
South Brittany
I checked the motor thismorning, running free its drawring .1 to .3A so back to the drawring board.
The motor block runs sort of ok on the track with no decoder, not as smothely as I would like so next I will try the decoder on the motor block with no loco body.
stockers
3,795
65
Nr. Ashford, Kent. England.
Add a load to the motor - the current may zoom up. My Mallet is perfectly happy at low speed - pulls about 0.2 amp but at full speed the XLS trips out. You can watch the current going up as you go above about speed step 9 (of 14). New motors one day but its OK at the moment - still pulls loads, its just speed that increases the amps.
French Chuffed
South Brittany
I loaded the free running motor today, with no significant ampere increase. So will re assemble the loco after checking the free movement of the valve gear.
