A new Railway is Started
4,465
74
The method you use to glue the ballast is the same one as what I used to advise my customers for indoor, but I did not know it worked outside. I thought the rain would wash away the glue. Does it really hold? I am most curious about your answer. If it really works, that would be great news to me.
Yes it works but you do need to use External Quality PVA (sometimes revered to as waterproof). I find the big plastic containers with I think a gallon (4 or so Litres) in work well. I get these from Builders Merchants.
railaddict
18 May 2020
99
10
72
Belgium
Thanks Jon, I had a quick look on the internet and found it, so it must be available from my local builders merchant. :)
1,382
59
Just like 1:1 railways your ballast will always need replacing and refixing, no matter what method you use
Harry
17 Dec 2009
92
Jon,
I'm very impressed by the appearance of the ballast, it's certainly the best I've seen for a long time. What are you using?
Regards, Harry.
4,465
74
Jon,
Regards, Harry.
It os 2-3mm Granite that I got from a place near Ipswich. I got the 2 bags seen in the pics for around£10. Recommended by another member “located to essex init” I think was where I found out about it. Plenty of chat on this thread about ballast.
Harry
17 Dec 2009
92
Thanks for the information Jon.
Regards, Harry
mole
5
ipswich
Regards, Harry
The place might be Band M concrete at Kirton 5 miles from Ipswich thats where I got some 2 weeks ago £5.95 a large bag 25 kilos ? heavy whatever size
4,465
74
Yes that is the place, I think they were also mentioned in a other thread that I posted on. Can completely recommend this as a great ballast medium as near to scale for us as you can find.
4,465
74
Further to glueing track down, a friend in Somerset uses SBR Bond neat from the plastic. I would be tempted to decant into the same type of containers that I show on my ballasting posts on page 11.
Mike well damped the track with an old kitchen spray of water and a drop of washing up liquid. Applied the SBR and then another good spray with water. Dries solid and clear as you can see here. But care is needed round points, I would give the moving parts a small dab of oil to stop any edhesion by splashed SBR and also go overboard with water spraying in those area. I do this with my PVA method.
4,465
74
A small project that has recently been carried out in Gernrode has been to organise the removable wagon loads. When Gernrode is over capacity of stock I have shelves for the overflow, but these already have a few permanent residents and have become a dumping ground for those removable wagon loads. Here you can see that they take the space that would accommodate 6 or so wagons. 3D923A21-EDBE-4651-A581-F1D0DADB17AC.jpeg
Below you can see Gernrode sidings full to capacity, all it needs is one of those vehicles to be another bogie vehicle or just 1 more wagon and the shelves come into play for more storage. Incidentally in those sidings are 20 4 wheel wagons, 1 bogie wagon and 5 bogie coaches. ABEA863A-0688-47A5-A8D0-AFEC1231D125.jpeg
Thus a small set of shelves have been created in a small dead area that was not big enough to extend the stock shelves due to the door, but just enough space was available for the 4 thin shelves to hold them loads. Thus I now have space for those pesky extra wagons that arrive during an operating session.
4,465
74
A couple of small jobs done today. I have been running with a couple of steam trams a sort of service between Harzegerode, Alexisbad, Magdesprung and Silberhütte these last few weeks. I have Lamps on both of the locomotives and to add to the fun these are swopped to the front at each change of train direction. Tail lamps are also added to the rear of the Trains. Trouble is I also use a couple of wagons in the fun and though I had fitted Lamp Brackets to the locs and tram coaches, the wagons were not so fitted. This has been attended to.
These are the lamp iron assemblies made out of tinplate as some of the lamps are magnetic. Simple cut, bend and glue in place. One wagon has a pin to give some mechanical fitting, the other bends round the handrail. All are fitted with additional 806 super glue to help keep them in place. Both these can take both types of Lamps, the locs and coaches are mire resricted to a single type of atttachment.
Below you can see how the differing irons have been fitted to the highly modified LGB Vans.
Below you can see how the Lamps fit, the Red Coloured Lamp on the van is a Magnetic one. The one with the Red Blob is a conventionally fitted one with a slot for the lamp to fit to the iron. You can also see the front lamp on the Loco, these two lamps came with the Loco which was an impulse buy at GRS. Much modified since then, having Deltang RC, a MLS Sound Card and many more batteries than the original 4 AA’s that powered it when bought. Oh yes it also has a Swift 16 adaptable length chassis with Delrin Chain powering all 4 wheels. The other Steam Tram also has similar modifications.
Running past the Water Tower at Magdesprung reminded me that some detail was required, water level indicator, water bag and the operating lever needed to be repaired.
Below you can see the Water Tower prior to mods.. I wrote this up in Mad days, it is just a flower pot with some kind of bird feeder top plonked in it. The stonework is chippings from cleaned up bricks with a wood door and rocket stick surrounds. The turn on/off standard is a moulded white metal one with part of the handle broken off.
Here you can see the water indicator during spraying, it is a simple bodge up using KS 6mm square tube with the indicator a piece of nickel silver cut to shape, this was soldered on with a small gap from the tube. A couple of bits of brass round also soldered on will be used to glue the indicator to the flower pot. The bag has been constructed from a couple of off cuts of brass tube and heat shrink.
Once the undercoat of Halfords etching primer had dried the lot was sprayed Halfords matt white, this then had some Tamiya 10mm masking tape added at 10 mm gaps to allow the lot to be sprayed Halfords matt black. Finally the indicator was painted red.
Below you can see the completed thing with the other Steam Tram in attendance for a well earned drink of puffer train beer.
Reactions: 1 users
4,465
74
Part of the joy of having a line like this is to have different things about. The brown one is a coach that I modified for Palstig, I also dug out the 3minutesof fame kit built Wisbech and Upwell coach to get something quite different and very much away from my East German theme.
75B449F9-A8D5-4EDE-962B-CCBE8152AEF0.jpeg 01142C05-D828-46A8-98DD-216656507AF9.jpeg 99C51AB6-9D9B-4806-8425-412A0FC9E764.jpeg
Another thing that has been bugging for a while is operation of the points that sit outside of the shed at Lindenburg.
To facilitate operation when shunting into the siding a point switch is required outside of the shed. I had done a test setup which worked fine on my test line but as the pipe runs were quite short it fooled me. When I set it up outside I could hear air constantly bleeding when one or the other switch was pulled off. Hardly surprising as when a lever is at normal that bleeds the air from the line allowing the air motor to return the point or signal to normal. So I revised things, now the switch outside needs to be reversed so that the switch inside can operate the points. Thus to operate them outside when shunting the inside lever needs to be reversed. Simples, in effect the inside lever provides air to work the points and removes it to return to normal. But when outside the same occurs but nothing happens unless the inside switch has been reversed. I hope my operators soon get the gist of how it works.
My next problem is what to I put on the outside switch as a label to explain all of the in 10-15 letters?
JimmyB
Shed Points Reverser
4,465
74
Possibly but that may cause more confusion as the points in question are outside!
The diagram below shows the 2 methods of piping up the Air. The wrong one leaked air when fitted outside. The red lines show where Air is fed when switches pulled (reversed). Clearly on the right set Sw1 must be reversed to get the motor to activate when Sw2 reversed.
4,465
74
If you care to look back toPage 6 Post #108 of this thread you can see my description of the Silberhütte Fuel Depot fit out. Over time the plastic fences have suffered a lot of damage, sundry repairs have been carried out but inevitably what I believe to be Pigeons landing has taken its toll. The remains (well those found anyway) have been unceromously dumped in the junk pile at Magdesprung.
So today it was time to solder up some replacements. I used the largest mains Copper Wire that I have, cut and bent to shape then soldered up. The bottom has short lengths of N/S wire soldered to the rear to push into small holes drilled in the surface I have not painted these up prefering them to weather over time though some brown paint has been used where solder shows. I somehow made one higher than the other 2, this sits where the Bogie Tank normally sits so can be bluffed away that that is the reason. Now held in place with super glue of some sort that has caused the white deposits and shiny surface. No worries looks suitably old and industrial to me. The remains of the old fences left in place to illustrate changes over the years to perhaps replace original metal fences stolen during the war or after years by who knows which authority.
E630CD1A-261F-4706-A95B-8D7E3A1F0727.jpeg 27BC8F70-8916-40AB-892A-69F6AD8FE498.jpeg
Do yer worse Pigeons.
4,465
74
Thats quite a realistic scrap yard there. :)
Thanks. Created over time, every time I have some junk or bits left over from a job they get dumped in one or other of the 3 junk areas. Nothing planned just evolves as a real one might do.
playmofire
23 Oct 2010
7,748
797
78
North Yorks
Yes, that thought went through my head when I read your original post on this, a full scale scrap yard approach to a G scale scrap yard.
