<font face="Times New Roman">Hi,
</font><p><font face="Times New Roman" size="3">I am extending (weather & bad back (getting better now) permitting) the railroad. This will include a custom built 90 degree crossing (I use Peco code 250 rail) so naturally a custom built hut for the keeper was needed. </font></p><p><font face="Times New Roman" size="3">Made from Korrofulute and plasticard, with underlayment (a new word for cheap roofing felt!) for the shingles it will be located on a small piece of roofing tile, which was kept after some extensions a while ago.</font></p><p><font face="Times New Roman" size="3">The windows were made first from my own jigs, from 2 layers of .020 strips, with .030 sides and .040 front frames, when complete the holes for them in the walls can be cut out. The door was built up 'in situ'</font></p><p><font face="Times New Roman" size="3">The usual drinking straw is used for the very necessary(in Colorado where the line is supposedly set) stove pipe. I double these adding another straw internally, cut it lengthwise to get it inside with a thin layer of glue and feed it inside, on both portions. Add a fixing wire to keep it still, and add paper bands for the fixing bands. The top is also a section of another straw glued over a piece of scrap that fills the top of the pipe, also close off the inner end of the horizontal section to deny bugs a home there!.</font></p><p><font face="Times New Roman"><font size="3">Paint to suit - and varnish it for protection with Johnson’s Klear, the roof will have a layer of Thompsons' Water Seal . </font><font size="3"> </font></font></p><p><font face="Times New Roman"><font size="3">Here are some photos of the little building</font>
</font></p>
</font></p>
